  • 8
Message 1 of 13
Hub 4 Inermittent speed
Hi everyone.
Since upgrading to a new hub 4 but remaining on the M350 service I have notice variances in the speed tests done within minutes of each other varying from 150mbs to 340mbs. With the hub 3 I was recording 360-370mbs. The hub 4 is in modem mode to a Netgear router and in in turn have ethernet connections to smart tvs and desktop. Only wifi is used for mobile devices.
Can someone review the logs below and confirm if everything looks normal? The hub restarted itself this afternoon but intermittently I notice the light on the hub flashing on and off for a couple of seconds.
  • 8
Message 2 of 13
Re: Hub 4 Inermittent speed
Thu 01/01/1970 00:01:175RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 15:25:235MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 15:28:246SW Download INIT - Via Config file cmreg-vmdg640-bbt062-b.cm
Fri 30/10/2020 15:30:026SW download Successful - Via Config file
Fri 30/10/2020 15:32:345MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 15:35:436CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 15:58:454DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 15:58:496CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 16:56:594DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 31/10/2020 07:29:096CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 31/10/2020 13:21:325MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:183No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 02/11/2020 10:44:595MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 02/11/2020 11:14:374DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 8
Message 3 of 13
Re: Hub 4 Intermittent speed
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
331000000
6.199997
38.983261
QAM256
25
1
139000000
11.900002
38.605377
QAM256
1
2
147000000
11.500000
38.983261
QAM256
2
3
155000000
11.400002
38.605377
QAM256
3
4
163000000
11.199997
38.983261
QAM256
4
5
171000000
10.599998
38.983261
QAM256
5
6
179000000
10.099998
38.983261
QAM256
6
7
187000000
10.000000
38.605377
QAM256
7
8
195000000
9.900002
38.605377
QAM256
8
9
203000000
9.500000
38.983261
QAM256
9
10
211000000
9.199997
38.983261
QAM256
10
11
219000000
9.000000
38.983261
QAM256
11
12
227000000
8.900002
38.983261
QAM256
12
13
235000000
8.900002
38.983261
QAM256
13
14
243000000
8.699997
38.605377
QAM256
14
15
251000000
8.599998
38.605377
QAM256
15
16
259000000
8.900002
38.983261
QAM256
16
17
267000000
8.800003
38.983261
QAM256
17
18
275000000
8.000000
38.983261
QAM256
18
19
283000000
7.099998
38.983261
QAM256
19
20
291000000
7.099998
38.983261
QAM256
20
21
299000000
7.400002
38.983261
QAM256
21
22
307000000
7.400002
38.983261
QAM256
22
23
315000000
7.000000
38.983261
QAM256
23
24
323000000
6.400002
38.605377
QAM256
24
26
371000000
5.199997
38.605377
QAM256
26
27
379000000
5.400002
38.983261
QAM256
27
28
387000000
5.099998
38.605377
QAM256
28
29
395000000
4.500000
38.605377
QAM256
29
30
403000000
4.199997
38.605377
QAM256
30
31
411000000
4.400002
38.983261
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
0
0
0
1
Locked
32623326
0
0
2
Locked
33076813
0
0
3
Locked
32810385
0
0
4
Locked
33497526
0
0
5
Locked
35644950
0
0
6
Locked
34809973
0
0
7
Locked
30806907
0
0
8
Locked
245600723
0
0
9
Locked
15579403
0
0
10
Locked
14785405
0
0
11
Locked
14794489
0
0
12
Locked
246576350
0
0
13
Locked
13937589
0
0
14
Locked
15893530
0
0
15
Locked
15221428
0
0
16
Locked
13136677
0
0
17
Locked
13736993
0
0
18
Locked
15126379
0
0
19
Locked
15191894
0
0
20
Locked
12682468
0
0
21
Locked
239118080
0
0
22
Locked
15840916
0
0
23
Locked
15035799
0
0
24
Locked
22077368
0
0
26
Locked
23488547
0
0
27
Locked
24623861
0
0
28
Locked
23547940
1
0
29
Locked
24033657
0
0
30
Locked
22443751
0
0
31
Locked
248579883
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
33
80
4K
1560
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
33
Locked
3.1
64275366
0
  • 25.21K
  • 1.45K
  • 3.21K
Message 4 of 13
Are you measuring speeds over Ethernet?
  • 12.3K
  • 952
  • 1.58K
Message 5 of 13
Several of your Downstream Power Levels are too high.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 8
Message 6 of 13
Yes measured over ethernet.
  • 8
Message 7 of 13
Mike
Thanks for looking at this, sorry I am new to Virginmedia and fibre. I cannot find any number to call on the VM website. Everything seems to be online guides can you please advise?
  • 12.3K
  • 952
  • 1.58K
Message 8 of 13
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone
Mike Robinson
  • 8
Message 9 of 13
Cheers Mike
  • 3.36K
  • 257
  • 333
Message 10 of 13
Hey @steamyb,
Sorry to hear of the issues that you've been having and I can see that you have had some help from the team but they haven't been able to resolve the issues for you.
I have looked over your network statistics on our side and can see that you have a problem with modem SNR across all of your channels and some the downstream channels power levels are too high and to resolve this we would need an engineer visit to your home.
I have arranged for the appointment and you can find all the information that you need about your appointment on your online account and clicking My Account and Order tracking.
Steven_L
