Message 1 of 9
Hub 4 Identifying devices
I have a new Hub 4 and I am trying to set names for my devices. However, whenever I set the name of a device on the Home page it is ignored and dropped back to Unknown in 9 out of 10 times. Some devices work most don't. Does anyone have the correct way to name devices.
BTW many Alexa WiFi devices are shown as ETHERNET connected 😞
thanks
  • 2.87K
  • 51
  • 263
Problem sorter
Message 2 of 9
Re: Hub 4 Identifying devices
Same bug as HUB3 initially and assume its due to immature Firmware.
I got the HUB4 to remember the names eventually by not changing the device type/icon so they all look the same now but at least the names stick.
Message 3 of 9
I seem to be limited to 7 devices that i can name - but some I cannot rename. Others that are renamed end up on a different device.
Not Good 😞
  • 2.87K
  • 51
  • 263
Problem sorter
Message 4 of 9
Yes I have had it swapping names around which is confusing, as I said as buggy as the HUB3 was/still is so they have not learned from the past.
  • 7.56K
  • 596
  • 1.28K
Legend
Message 5 of 9
If you are going to the expense of a 1G circuit I would only ever use the hub4 in modem mode.
  • 2.87K
  • 51
  • 263
Problem sorter
Message 6 of 9
No point if the Lan Ports on HUB4 is limited 1Gb/s, I could buy the Asus Mesh WIFI 6AX kit and see what the WIFI would get me as my PC is WIFI 6AX 2400+
I ideally do not really need really fast WIFI, my PC and NV Shield TV are wired.
Message 7 of 9
I don't use 1G, Virgin just "upgraded "met Hub 4.
No need for extra hardware.
  • 4.57K
  • 268
  • 525
Message 8 of 9
Hello Buttshill
Thanks for your post and sorry to hear about the issues you are having
Have you been able to sort this yet, if not then let me know and I can go away and find the answers
Gareth_L
  • 2.87K
  • 51
  • 263
Problem sorter
Message 9 of 9
How can the end user fix this issue it still happens in the HUB3 but not as much.
It would take a new Firmware but then again VM did not listen to "us" beta testers.
