Hub 4 Horrible
RichLutz
Appologies if this is in the incorrect section im new and i wanted to talk about the dreadful HUB 4 and the issues ive had over the last week -
Okay so firstly VM sold me into their GIG1 Package from my M500, Sent me the HUB4 out two days later got it activated and my speed didn't push past 20MB down wired and 6MB wireless,
Connected it into Modem Mode and ran my trusty DECO M5 Mesh connection instead, speeds improved but still quite poor,
Phoned up CS and they rebooted and sent an install Kick this did the job and was flying along at the advertised speeds.
24 Hours later back to square 1 again and slow slow connections, phoned CS the Guy says theres a lot of interferance its coming back as so im going to send an engineer in two days time.
Got up bright and early got a phone call at 8am from the Tech - We dont have GIG1 in your area so i can't come out and look or fix anything as were not trained on it so CS will call you and downgrade your package back to M500
Here is were the bigger issues began :
Firstly they have the incorrect package price of £44 as agreed there charging me £60 and wont do much about it.
And my speeds are basically BT FIBRE 1 Now -
Ive rebooted and reset the HUB4 Multiple times and used my DECO M5 & reset multiple times but my speeds are incredibly slow and nobody on the phone seems to be that interested somehow they have booked me an engineer out monday 1pm onwards to move the hub?
I think i need another hub preferably the hub3 again haha.
This morning i have reset it all again and turned it into modem mode but guess what?
The WIFI Is still being broadcast from the HUB4 as well as the DECO Mesh Network so somewhere along the lines the HUB4 Isn't doing as it's told and sounds the culprit to me.
Anyway from VM here have a closer look or someone offer me more advice as im pulling what hair i have left out and it's frustrating to say the least.
Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
Tom_F
Hi RichLutz, thanks for getting in touch.
Really sorry to hear about the problems you've had with your broadband upgrade & hub replacement. I wasn't able to check on this using your forum info alone on this occasion, if you get back to me via PM we'll do all we can to help get things sorted.
Tom
22 REPLIES 22
Might be worth starting from scratch first. Can you do this.....
__________________________________________________
Before starting ensure the primary Deco unit is set to be in Automatic IP i.e. DHCP (& Nat) mode, Then disconnect it and the other units and switch them off. Then pinhole reset the Hub exactly like this....
Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
Then, put the VM Hub back into modem mode ( https://www.virginmedia.com/help/virgin-media-hub-modem-mode ) and wait for it to initialise 5-10 min.
Once it’s in modem mode, the VM hub “MUST” then be powered off. Switch your Deco primary unit on on and make sure it’s fully initialised (leave 5 min) and only then put in the ethernet cable from its WAN port to the VM hub (any port will do).
NOW… power up the VM hub and wait 5-10 minutes for The Hub to initialise and and you should get a connection. Use the recommended App to connect th other Deco units to the first one.
See if that stabilises things - report back
Thanks for the reply !
done everything as described and to no avail.
I left the Hub4 just running as normal without the deco system setup or switched on and the Wi-Fi was the same as was hard wired even after resetting back to factory default
i left it for two hours and still same problems.
what is strange though is that if I run a test using samknows it’s giving me a higher upload than download ?
after two hours I reset all again and setup deco as new system and it still stayed the same speed if not got a little worse then a little better.
If I run a speed test using Sam knows I get the same results , if I use Google’s through chrome on Wi-Fi it showed 302mb down but couldn’t record an upload speed , if I use it Ethernet it’s the same speeds.
tested on fast.com max speed that reports is 42mb at the moment.
im going to try post the figures from the Hub4 page in a moment to see what you all think.
regards
Please cut and paste all the stats, the photos are extremely unclear.
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
331000000
6.900002
40.946209
QAM256
25
4
163000000
7.400002
43.376591
QAM256
4
5
171000000
7.300003
40.946209
QAM256
5
6
179000000
7.099998
40.946209
QAM256
6
7
187000000
7.000000
43.376591
QAM256
7
8
195000000
6.900002
43.376591
QAM256
8
9
203000000
6.900002
40.946209
QAM256
9
10
211000000
6.900002
43.376591
QAM256
10
11
219000000
6.900002
43.376591
QAM256
11
12
227000000
6.900002
40.946209
QAM256
12
13
235000000
6.800003
40.946209
QAM256
13
14
243000000
6.900002
43.376591
QAM256
14
15
251000000
6.800003
40.946209
QAM256
15
16
259000000
7.099998
40.946209
QAM256
16
17
267000000
7.199997
40.946209
QAM256
17
18
275000000
7.000000
40.366287
QAM256
18
19
283000000
6.000000
40.946209
QAM256
19
20
291000000
5.900002
40.366287
QAM256
20
21
299000000
6.400002
40.946209
QAM256
21
22
307000000
7.300003
40.946209
QAM256
22
23
315000000
7.400002
40.946209
QAM256
23
24
323000000
7.300003
40.366287
QAM256
24
26
339000000
6.800003
43.376591
QAM256
26
27
347000000
6.900002
40.946209
QAM256
27
28
355000000
6.900002
43.376591
QAM256
28
29
363000000
7.099998
40.946209
QAM256
29
30
371000000
7.500000
43.376591
QAM256
30
31
379000000
7.400002
40.946209
QAM256
31
32
387000000
7.500000
40.946209
QAM256
32
33
395000000
7.199997
40.946209
QAM256
33
34
403000000
6.599998
40.946209
QAM256
34
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
40.946209
0
0
4
Locked
43.376591
0
0
5
Locked
40.946209
0
0
6
Locked
40.946209
11
0
7
Locked
43.376591
0
0
8
Locked
43.376591
0
0
9
Locked
40.946209
0
0
10
Locked
43.376591
0
0
11
Locked
43.376591
0
0
12
Locked
40.946209
0
0
13
Locked
40.946209
0
0
14
Locked
43.376591
0
0
15
Locked
40.946209
1
0
16
Locked
40.946209
1
0
17
Locked
40.946209
0
0
18
Locked
40.366287
0
0
19
Locked
40.946209
0
0
20
Locked
40.366287
0
0
21
Locked
40.946209
0
0
22
Locked
40.946209
0
0
23
Locked
40.946209
0
0
24
Locked
40.366287
0
0
26
Locked
43.376591
0
0
27
Locked
40.946209
0
0
28
Locked
43.376591
0
0
29
Locked
40.946209
1
0
30
Locked
43.376591
0
0
31
Locked
40.946209
0
0
32
Locked
40.946209
1
0
33
Locked
40.946209
0
0
34
Locked
40.946209
1
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
35
96
4K
1880
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
35
Locked
45
6.1
53132400
0
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
45.770599
5120 KSym/sec
64QAM
2
2
46200000
45.520599
5120 KSym/sec
64QAM
1
3
32600000
46.020599
5120 KSym/sec
64QAM
3
4
25800000
46.270599
5120 KSym/sec
64QAM
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
1
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt053+voc-b.cm
SFID
187210
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
187209
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Appologies for the multi post this was the only way i could get it to do it 🙂
If you see anything that does not look right there let me know,
Also im still able to access the HUB Config page even through using a deco mesh network hard wired/wirlessly on the old hub3 i was unable to do this is this a new feature or a fault?
Nothing stands out in those stats, a few Pre RS errors are to be expected and they are correctable. It’s a known problem/fault that you can still access the Hub4 on both 192.168.0.1 and 192.168.100.1. Out of curiosity what is the IP address of your master node.
