  • 5
Hub 4 Factory Reset
Do any of you know how to perform a factory reset on Hub 4?
  • 12.25K
  • 948
  • 1.57K
Re: Hub 4 Factory Reset
Try the same method as used for the Hub 3 ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Mike Robinson
  • 5
Thank you soo much, that worked perfectly.
