dispyr
  • 12
Hub 4 Connection to smart plug issues
Everything is fine with my new Hub 4 except the connection issues to my smart plug (V-TAC). The hub is connecting with 2.4GHz but not allowing the device to connect to the internet and therefore not allowing it to join my home network and alexa.  I have tried all sorts of combinations using the WPS etc with no success. Any ideas.
These are the readings I get from the Hub connections:
**:**:**:**:**:**192.168.0.141Wi-Fi 2.4G VM9130463
unknown**:**:**:**:**:** 1Wi-Fi 2.4G VM9130463
gary_dexter
  • 31.33K
  • 1.94K
  • 4.22K
Re: Hub 4 Connection to smart plug issues
Make sure the 2.4Ghz band is enabled for b/g/n connections.
dispyr
  • 12
Thanks for that and checked but no solution yet - I had not thought about this possibility.
Samlaval
I am having the same issues! Spent the last two hours trying to sort this out but nothing! Spoke to someone from Virgin on the phone but they were useless.
Martin_N
  • 6.21K
  • 258
  • 367
Hi dispyr,
Thank you for your post. I'm very sorry to hear about the issue you're having with your Tv.
Just to confirm are you having this issue with any other device? Are you getting any specific error messages?
^Martin
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
@Samlaval wrote:
If you want assistance please start your own thread.
