Hub 4 - Connect App/Public Wifi
I've just updated to the Vivid 1GB package/Hub 4.
It seems I can't opt out of public wifi (I can see the "Virgin Media" network has appeared, I had opted out on my old Superhub 3). The option to opt out is missing from the my profile page on My Virgin Media website.
I can't use the VM Connect App (I thought I might be able to unsubscribe there) - it seems to only support the hub 3 - it won't connect to hub 4.
How do I get rid of this thing? I'm not interested in it. Also when will the connect app support the hub 4?
Cheers
  • 14.61K
  • 1.57K
  • 3.26K
Re: Hub 4 - Connect App/Public Wifi
The 1Gig/Hub4 service in Southampton is a trial, so is running outside the normal systems everyone else is using.
Click to learn more about VIP
Use Kudos to say thanks
Intriguing, no step of the process ever told me it was a trial... I just knew it wasn't available everywhere yet. There's no warnings/provisos saying that they don't fully support it yet or that I'm "testing" some kind of pre-release product.
I wonder if VM support can opt me out of public wifi remotely, since the option on their website doesn't seem to exist any more...
  • 5.14K
  • 360
  • 886
Superstar
Gig1 is not a trial, it's also being rolled out in Manchester and eventually nationwide.
If opt out isn't possible then the only solution is to put the hub 4 into modem mode and use your own router.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
