addag
Just joined
Hub 4 2.4 ghz not working
Just signed up as a new customer and have been struggling to get the 2.4 GHz working. The technical support is absolutely hopeless. The people are rude. In spite of explaining the issue in detail and being a network engineer myself & having tried all possible options, the person was trying to act smart as if they were speaking to an idiot.
To add, I have already tried all options like different names for 2.5 & 5 ghz network, disabling smart option, changing channels, modes, etc. Nothing works
Got sent a new box today and although this one is broadcasting the 2.4 network, it is not getting connected to the internet. Seems more like a software bug. Looks like will have to waste another hour trying to speak to someone.
if anyone has a solution, please let me know
  • 22.5K
  • 2.41K
  • 4.02K
Re: Hub 4 2.4 ghz not working
If you have had 2 Hubs and the same issue is persisting - and this board is not full of identical complaints - it would seem that this is a problem specific to your set up - no?
Do wired connections work ok and do 5GHz devices connect fine? I am no expert - but wifi being broadcast and not connecting to the network is often a DHCP/DNS issue on the devices being in the wrong "range".
Are you in modem mode with your own router by any chance?
addag
Just joined
Two hubs two different issues.
one does not broadcast 2.4 ghz network, the other although does broadcast it but does not connect to the Internet using the same cable
Wired and 5Ghz does work fine. It is not an issue with DNS/DHCP
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
If you've been sent a new hub you need to keep it plugged in to allow it to activate
  • 15.93K
  • 688
  • 1.56K
likely the secondhand hub you got has wifi problems seems all hub have this problem, you will save time getting your own wireless router with 1Gb ports and use the hub in modem mode.
David_Bn
  • 4.95K
  • 227
  • 403
Good Afternoon addag,
Thanks for your post on our Community Forums and a very warm welcome to you!
Sorry to see that establishing a connection to the 2.4GHz band has been troublesome.
Looking into your hub, I can see that you currently have 3 devices connected to this band. Are you able to use the services as expected on the band since your post?
Kindest regards,
David_Bn
