AmMin
  • 27
Message 11 of 20
Re: Hub 4 1Gbps not delivering
Hello Kath_F
PART 2
Speeds into the Hub consistently falling below the minimum speed guarantee. In this PART 2 I am only looking at speed INTO the hub
SamKnows shows that the speed into Hub is consistently below the speed guarantee and never consistently delivers anything approaching the contracted speed or the guaranteed minimum speed.  This happens on consecutive days. Please see date/time on the screen shots and photos
Frequently there is an error message that the “router could not be found” or “something went wrong” or says it is “…offline” even when it has full power and a solid white light and will display these messages whether using WiFi or over an ethernet connection.
There are more photos.screen shots
The service I pay for is 1 Gbps. I am not getting that on a consistent basis. And over several consecutive days
What is wrong with the speed into my Hub 4 and how is it put right?
AmMin
  • 27
Message 12 of 20
Hello Kath_F
PART 3
Speeds out of the Hub consistently low on Ethernet. In this PART 3 I am only looking at speed OUT of the hub
Speeds are consistently sub 500 Mbps using an Ethernet cable whilst testing different PC’s (both running W10 with all drivers up to date); using different Ethernet cables from CAT 6 to 7 and across different browsers. Between 10 and 13/09 over an Ethernet connection
  • SamKnows speeds to my PC were between a low of 178 to a high of 346 Mbps (except when not recognizing the router when it was zero
  • Ookla was between a low of 112 to a high of 481 Mbps with uploads between 35 to 47Mbps with one momentary flash of 953Mbps.
This one example proves high speeds are possible but are simply not happening.  None of the speeds get anywhere near 1Gbps on a consistent basis. And yes, the ports on my PC are more than capable of these speeds
Why am I not getting circa near 1 Gbps over an Ethernet cable out of the Hub?
You can see the average speed results from Ookla on my earlier posts. For clarity all these images are over an Ethernet connection so should be more than 900 Mbps.
AmMin
  • 27
Message 13 of 20
Hello Kath_F
PART 3
There are latency spikes. In this PART 3 I am only looking at the latency issues
There are latency spikes each day that are not present in the evening.
Some of the spike occur on a regular repeating 4 of 8-hour interval pattern. Virgin, please stop pinging me and affecting my service.
These latency spikes suggest there is a fault or utilisation or capacity issue issue in the London SW13 area. Not all the experts who contribute their time to helping us agree on this topic or the implications of this.
I am losing internet connection/dropping out when video conferencing or when doing remote access for IT support.
Here are some sample BQM images. My BQM images may be better than some of the ones posted on the fora but it feels as if there are issues
AmMin
  • 27
Message 14 of 20
Hello Kath_F
PART 4
This section deals with my router logs and shows an increase in the 3.1 downstream uncorrectables.
I have a few T3 errors that tend to increase each day. From what I can see T3 timeouts can lead to RCS Partial Service (Downstream) and can manifest as a dropped connection while the hub renegotiates its channels! I think this is shown in the log stats.
The big issues is the number of Uncorrectables (Post RS Errors) in the 3.1 downstream that increase each day and indicate, given other fora answers, a likely noise problem.
Cable Modem Status
ItemStatusComments
Cable Modem StatusOnlineDOCSIS 3.1
Primary downstream channelLockedSC-QAM
Channel OverviewDownstreamUpstream
DOCSIS 3.0 channels314
DOCSIS 3.1 channels10
3.0 Downstream channels
92030000005.90000240.366287QAM2569
11390000005.90000240.366287QAM2561
21470000005.90000240.366287QAM2562
31550000005.80000340.366287QAM2563
41630000005.59999840.366287QAM2564
51710000005.19999740.946209QAM2565
61790000005.59999840.366287QAM2566
7187000000640.366287QAM2567
81950000005.80000340.946209QAM2568
102110000005.90000240.366287QAM25610
112190000006.09999840.946209QAM25611
122270000006.19999740.366287QAM25612
132350000006.30000340.366287QAM25613
142430000006.69999740.946209QAM25614
152510000006.09999840.366287QAM25615
16259000000640.366287QAM25616
172670000005.90000240.366287QAM25617
182750000006.09999840.366287QAM25618
192830000006.69999740.946209QAM25619
202910000006.09999840.366287QAM25620
212990000005.80000340.366287QAM25621
223070000005.80000340.366287QAM25622
233150000005.90000240.366287QAM25623
24323000000740.366287QAM25624
253310000007.540.946209QAM25625
263390000007.19999740.366287QAM25626
273470000007.40000240.946209QAM25627
283550000006.80000340.946209QAM25628
293630000007.19999740.366287QAM25629
303710000007.40000240.366287QAM25630
313790000006.80000340.366287QAM25631
ChannelLock StatusRxMER (dB)Pre RS ErrorsPost RS Errors
9Locked40.36628700
1Locked40.36628700
2Locked40.36628700
3Locked40.36628700
4Locked40.36628700
5Locked40.94620900
6Locked40.36628700
7Locked40.36628700
8Locked40.94620900
10Locked40.36628700
11Locked40.94620900
12Locked40.36628700
13Locked40.36628700
14Locked40.94620900
15Locked40.36628700
16Locked40.36628700
17Locked40.36628700
18Locked40.36628700
19Locked40.94620900
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.36628700
25Locked40.94620900
26Locked40.36628700
27Locked40.94620900
28Locked40.94620900
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
3.1 Downstream channels
ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
41964K1880QAM4096759
Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
41Locked449.72893647602554
3.0 Upstream channels
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
13940000043.7705995120 KSym/sec64QAM4
24620000044.0205995120 KSym/sec64QAM3
36030000044.7705995120 KSym/sec64QAM1
45370000044.5205995120 KSym/sec64QAM2
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
1US_TYPE_STDMA0000
2US_TYPE_STDMA0020
3US_TYPE_STDMA0000
4US_TYPE_STDMA0010
AmMin
  • 27
Message 15 of 20
continuing PART 4
General Configuration
Network accessTRUE
Maximum Number of CPEs1
Baseline PrivacyTRUE
DOCSIS Mode3.1
Config filecmreg-vmdg640-bbt076-b.cm
SFID48
Max Traffic Rate1200000450
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID47
Max Traffic Rate55000270
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypebestEffort
TimePriorityDescription
Mon Aug 23 17:09:49 20216CM-STATUS message sent. Event Type Code: 23; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Pr
Mon Aug 23 17:09:49 20213No Ranging Response received - T3 time-out;C
Mon Aug 23 17:09:54 20216CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A;
Mon Aug 23 17:09:59 20213No Ranging Response received - T3 time-out;C
Mon Aug 23 17:10:00 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Mon Aug 23 17:10:06 20213No Ranging Response received - T3 time-out;C
Mon Aug 23 17:10:08 20216CM-STATUS message sent. Event Type Code: 5; Chan ID: 25; DSID: N/A;
Mon Aug 23 17:10:13 20213No Ranging Response received - T3 time-out;
Mon Aug 23 17:10:46 20213Ranging Request Retries exhausted;
Mon Aug 23 17:10:46 20213Unicast Maintenance Ranging attempted - No response - Retries exhausted;
Mon Aug 23 17:10:54 20213No Ranging Response received - T3 time-out
Mon Aug 23 17:11:09 20213Ranging Request Retries exhausted;
Mon Aug 23 17:11:09 20213Unicast Maintenance Ranging attempted - No response - Retries exhausted;
Mon Aug 23 17:11:29 20213No Ranging Response received - T3 time-out;
Mon Aug 23 17:11:47 20213Ranging Request Retries exhausted;
Mon Aug 23 17:11:47 20213Unicast Maintenance Ranging attempted - No response - Retries exhausted;
Mon Aug 23 17:11:53 20213Ranging Request Retries exhausted;
Mon Aug 23 17:11:53 20213Unicast Maintenance Ranging attempted - No response - Retries exhausted;
Mon Aug 23 17:12:41 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;
Mon Aug 23 17:30:17 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Thu Aug 26 12:36:08 20214DHCP RENEW WARNING - Field invalid in response v4 option;;
Thu Aug 26 16:06:06 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID:
Sun Aug 29 22:36:47 20214DHCP RENEW WARNING - Field invalid in response v4 option;;
Mon Aug 30 09:57:43 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Wed Sep 1 14:01:54 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;
Wed Sep 1 16:37:21 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
From prior log files
Fri Sep 3 18:19:17 20214DHCP RENEW WARNING - Field invalid in response v4 option;
Sat Sep 4 08:12:44 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Mon Sep 6 16:50:15 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Thu Sep 9 08:43:31 20213No Ranging Response received - T3 time-out;
Thu Sep 9 14:29:37 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Fri Sep 10 02:58:05 20214DHCP RENEW WARNING - Field invalid in response v4 option;
Fri Sep 10 08:22:57 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Fri Sep 10 17:49:13 20213No Ranging Response received - T3 time-out;
Fri Sep 10 19:25:27 20216CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Sat Sep 11 04:18:37 20213No Ranging Response received - T3 time-out;
Thu Aug 19 20:15:15 2021 5MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Fri Aug 20 07:15:23 2021 6CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Fri Aug 20 20:40:14 2021 3No Ranging Response received - T3 time-out;
Fri Aug 20 21:34:37 2021 6CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Sat Aug 21 10:55:28 2021 3No Ranging Response received - T3 time-out;
Sat Aug 21 11:22:42 2021 6CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Sun Aug 22 19:37:24 2021 4DHCP RENEW WARNING - Field invalid in response v4 option;
Mon Aug 23 08:09:46 2021 6CM-STATUS message sent. Event Type Code: 24; Chan ID: 41; DSID: N/A;
Mon Aug 23 17:03:49 2021 3SYNC Timing Synchronization failure - Loss of Sync;
Mon Aug 23 17:03:52 2021 6CM-STATUS message sent. Event Type Code: 2; Chan ID: 1; DSID: N/A;
Mon Aug 23 17:03:53 2021 5Lost MDD Timeout;
Mon Aug 23 17:06:08 2021 3Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;C
Mon Aug 23 17:06:52 2021 3No Ranging Response received - T3 time-out;
Mon Aug 23 17:06:57 2021 6CM-STATUS message sent. Event Type Code: 5; Chan ID: 23; DSID:
Mon Aug 23 17:06:59 20213No Ranging Response received - T3 time-out
Mon Aug 23 17:07:09 20216CM-STATUS message sent. Event Type Code: 23; Chan ID: 41; DSID:
Mon Aug 23 17:07:12 20213No Ranging Response received - T3 time-out;
Mon Aug 23 17:07:14 20216CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A;
Mon Aug 23 17:07:18 20213No Ranging Response received - T3 time-out;
Mon Aug 23 17:09:33 20216CM-STATUS message sent. Event Type Code: 16; Chan ID: 41; DSID: N/A;
Mon Aug 23 17:09:35 20213No Ranging Response received - T3 time-out;
Mon Aug 23 17:09:38 20213SYNC Timing Synchronization failure - Loss of Sync;C
AmMin
  • 27
Message 16 of 20
Continuing Part 4: Uncorrectables
If we look just at the 3.1 D/S and the changes to the uncorrectables over the last week from 12/09 to 18/09 we see
3.1 Downstream channels 18/09
3.1 Downstream channels 17/09
41Locked449.82154496012379
3.1 Downstream channels 16/09
41Locked449.91516377172064
3.1 Downstream channels 12/09
41Locked429.537994815127
Today, 20/09/2021 the router logs seem strange. It tells me there are no T3 errors, that there are no uncorrectables and that the entire page relating to the Network Log is blank. Frankly, I do not believe what it is telling me as the service has not improved!
Summary
Thanks Kath_F and I look forward to talking with the engineer and with understanding what is going on before I add my own WiFi to the Hub 4 and kick it into modem mode. You said there were some issues with the hub and it would be good to understand what those were/are.
Any other great thoughts/suggestions welcome
Apologies for the long reply post as there are some important issues and some of these issues are inter-related
AmMin
  • 27
Message 17 of 20
Today, 21/09 the most notable things on the router stats is that the Network Log remains blank with no data (even after a refresh) and that the uncorrectables increased over the last 24 hours even though the rest of the tables 'shows' there are no Post RS Errors or T3 errors. Guess this can only mean that the Hub records are faulty and not reporting properly
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
41
Locked
43
9.5
97377427
224
I have an engineer booked to visit and Virgin say the downstream levels are out of spec. I have asked for someone at Virgin to explain what that means as one month ago the downstream levels were out of spec and an engineer visited and said everything was fine yet the same issues remain.
  • Can someone please explain which of the downstream things are out of spec; what that means and what needs to happen to fix it and if this is fixed does it sort out the issues set out in this post
  • The minimum speed guarantee has been missed over consecutive days
  • The speed out of the hub over Ethernet remains far too low
  • There are latency spikes and video conference or remote access is problematic
I am unwilling to spend cash on my own tri-band WiFi 6 router/mesh unless I know the Hub 4 is working properly.
Many thanks everyone
Zoie_P
  • 3.56K
  • 156
  • 284
Message 18 of 20
Hi AmMin,
Thanks for keeping us posted, I can see a repull has been booked and we are hoping this will improve your services, Please keep us posted.
Zoie
John_GS
  • 10.68K
  • 551
  • 976
Message 19 of 20
Thanks for joining us on PM @AmMin
Just to update the thread, the repull was done but not fixed things, a further tech has been booked as a few of the downstream channels are out of spec.
You can track this tech visit in your online account
Let us know how the visit goes.
Best
John_GS
John_GS
  • 10.68K
  • 551
  • 976
Message 20 of 20
Thanks for the message @AmMin
Just to update the thread, the visit date has been changed. Going forward, please pop any updates publicly so we can assist further
Best
John_GS
