on 21-05-2022 19:47
Our Hub 3 keeps dropping connections intermittently to most of our devices (Windows 10 & various versions of Android). This happens on wireless and wired connections. I have set the hub to default, but this didn't help. The original settings on the hub have not changed for some years, but it has only just in the last couple of weeks that there has been a problem. Restarting the hub solves the problem for a short time, but the problem comes back. My only guess that there is a hardware fault with the Hub. Any other ideas?
Thanks.
on 31-05-2022 13:12
It looks like resetting the hub to factory default has not helped. Everything was fine for 5 days, but we are now back to square one with the hub which just cuts off any device that requires an IP Address from the DHCP Server. When I set the hub to factory default, I put 1 PC to a static IP Address - this has not had any problems. To my mind, this confirms that there is a failure with the hub.
on 29-11-2022 14:41
on 01-12-2022 16:38
Hi iamthenewph7, thanks for the message and welcome back to the forums.
I am sorry to hear that you were having issues with the hub 3 and glad to hear that this is now resolved.
Please let us know if you need any further assistance.
Kind regards, Chris.
on 08-12-2022 12:56
on 12-12-2022 08:55
Sorry to hear another issue has come up @iamthenewph7
Just to confirm, is this how you set up your landline? Look here. Do you have a dial tone at all? What happens when trying to make and receive calls?
on 14-12-2022 11:13
on 16-12-2022 15:31
Hi iamthenewph7,
Thank you for reaching back out, sorry to see you are facing a strange issue with your 5 Phone handsets and randomly 1 stops ringing, this does sound more like a device issue rather than the Router, as it is random which one doesn't ring, have you reached out to the Manufacturer help forums to see if anyone else has faced the same issue?
Paul.
on 16-12-2022 17:23
on 18-12-2022 17:43
Hello iamthenewph7.
Sorry to hear you are still having an issue with handset.
I'd like to take a look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
