on 28-02-2022 14:55
My hub 3 has no sticker on the bottom with admin password
how do I get this?
thanks
on 28-02-2022 15:00
on 28-02-2022 15:08
The hubs also normally come with a small plastic card with it on that slides in to the slot at the bottom of the hub.
on 28-02-2022 17:38
WiFi password is on tag but not admin password
on 28-02-2022 17:41
the default password on Hub3 is "changeme" if i recall correctly, or that may be for the 2ac, but worth trying
on 28-02-2022 17:43
on 02-03-2022 18:06
Hi @Rnshepherd5756, thanks for your post although I'm sorry that your Hub is missing some details you need.
Are you trying to access the Hub's settings via 192.168.0.1? It is also known as a Settings Password if so, please make sure that it is not listed as that, as it's strange for the wifi password to be on there but not the settings password - I would've expected both to be missing rather than just one!
I can also see that your Hub isn't new, you have had this for a while so have you ever potentially logged into your Hub Settings before because if so, you may have changed the password to something you remember that is personal to you?
Many thanks
