Sajidahkawther1
  • 8
Message 1 of 18
Hub 3
My hub 3 randomly stops working 3 times a day, but it doesn't happen at certain times. I want to know how I could get a replacement or even better upgrade to the hub 4 since I had the same issue and since my speeds are very low
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 18
Re: Hub 3
Is that on wired or wireless connections?
  • 23.98K
  • 2.54K
  • 4.36K
Message 3 of 18
Re: Hub 3
Stops working - how?
Is it only evident on wifi connections or do you see the issues at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
And... what are the various Hub lights showing/doing when this happens?
Sajidahkawther1
  • 8
Message 4 of 18
Re: Hub 3
Both
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 5 of 18
Re: Hub 3
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
  • 23.98K
  • 2.54K
  • 4.36K
Message 6 of 18
Re: Hub 3
Hub lights?
Sajidahkawther1
  • 8
Message 7 of 18
Re: Hub 3
It starts flashing yellow or green when it stops working
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 8 of 18
Re: Hub 3
Sounds to me like the hub is losing connection to the CMTS!
Post up the hub stats - let's see if anything stands out!
Sajidahkawther1
  • 8
Message 9 of 18
Re: Hub 3
Cable Modem Status
Item Status Comments
331000000
Locked
Ranged Upstream Channel (Hz)
60299930
Locked
Provisioning State
Online
1 331000000 -4.5 40 256 qam 25
2 267000000 -4.4 40 256 qam 17
3 275000000 -4.5 40 256 qam 18
4 283000000 -4.5 40 256 qam 19
5 291000000 -4.5 40 256 qam 20
6 299000000 -4.2 40 256 qam 21
7 307000000 -4.2 40 256 qam 22
8 315000000 -4.4 40 256 qam 23
9 323000000 -4.4 40 256 qam 24
10 339000000 -4.7 40 256 qam 26
11 347000000 -4.7 40 256 qam 27
12 355000000 -4.9 40 256 qam 28
13 363000000 -4.7 40 256 qam 29
14 371000000 -5 40 256 qam 30
15 379000000 -5.5 40 256 qam 31
16 387000000 -5.7 40 256 qam 32
17 395000000 -5.7 40 256 qam 33
18 403000000 -5.7 40 256 qam 34
19 411000000 -6 40 256 qam 35
20 419000000 -6.2 40 256 qam 36
21 427000000 -6 40 256 qam 37
22 435000000 -6 40 256 qam 38
23 443000000 -6 40 256 qam 39
24 451000000 -6.2 40 256 qam 40
1 Locked 40.3 4 0
2 Locked 40.9 6 0
3 Locked 40.9 5 0
4 Locked 40.9 6 0
5 Locked 40.9 15 0
6 Locked 40.3 7 0
7 Locked 40.9 5 0
8 Locked 40.3 6 0
9 Locked 40.3 5 0
10 Locked 40.9 6 0
11 Locked 40.9 6 0
12 Locked 40.9 4 0
13 Locked 40.3 6 0
14 Locked 40.9 7 0
15 Locked 40.3 10 0
16 Locked 40.3 4 0
17 Locked 40.3 4 0
18 Locked 40.9 8 0
19 Locked 40.3 5 0
20 Locked 40.3 9 0
21 Locked 40.9 5 0
22 Locked 40.3 20 0
23 Locked 40.3 6 0
24 Locked 40.3 0 0
1 60299930 48.5 5120 64 qam 9
2 39400009 46.5 5120 64 qam 12
3 46200021 47 5120 64 qam 11
4 53699986 48.5 5120 64 qam 10
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 1 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
kfoA,.iyewrkldJKDHSUBsgvca698
SFID 6068
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 6104
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type Best Effort
19/07/2021 12:14:6 notice LAN login Success ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2021 11:56:24 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 17:38:36 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 10:21:40 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 08:35:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/07/2021 23:47:31 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/07/2021 23:47:31 Error DHCP RENEW WARNING - Field invalid in response v4 option; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:56:35 critical No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:56:35 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:56:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:56:16 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:55:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:55:55 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:55:49 critical No Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2021 12:55:49 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2021 21:57:43 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2021 05:04:35 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2021 05:04:35 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2021 05:04:33 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2021 23:43:2 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 10 of 18
Re: Hub 3
SOme of your downstream channels are too low power-wise!
That'll need VM to book a Tech to rectify!
(Unless there's an attenuator at the end of the cable going into the hub - if there is, remove it and your connection will likely improve!)
