Davies13
  • 6
Message 1 of 15
Hub 3
My Hub 3 had a white power light which recently changed to orange but is now red. Not moved it at all; in open and airy position. Any ideas please?
Z92
  • 2.25K
  • 186
  • 350
Problem sorter
Message 2 of 15
Re: Hub 3
Unplug it from the wall, leave it a few minutes and then plug it back in.
If it stays red it'll be new hub time unless you have configured it for modem mode.
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 3 of 15
Re: Hub 3
Aye - usually a sign that the hub thinks that it is overheating (if in router mode)
Davies13
  • 6
Message 4 of 15
Re: Hub 3
Thanks for your reply but how do I find out if it's in router mode or modem mode (mentioned by other reply)?
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 5 of 15
Re: Hub 3
Are you accessing WiFi through the hub or your own router?
If it is the hub then you are in router mode!
Zak_M
  • 3.4K
  • 214
  • 340
Message 6 of 15
Re: Hub 3
Good afternoon @Davies13
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you are having some issues with your hub.
A red light normally means that the hub is over heating, I have taken the opportunity to get a an engineer out to you so that we can get this replaced.
Kind regards,
Zak_M
Davies13
  • 6
Message 7 of 15
Re: Hub 3
Hello Zak-m
Thanks for your reply.
Any idea of date and time slot when an engineer will call please?
Davies13
Zak_M
  • 3.4K
  • 214
  • 340
Message 8 of 15
Re: Hub 3
Sorry @Davies13
I should have said, you can find this via your my virgin media account.
Kind regards,
Zak_M
Davies13
  • 6
Message 9 of 15
Re: Hub 3
Hi Zak-M
Will this info be in the 'my orders & appointments' section of my account?
Thanks.
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 10 of 15
Re: Hub 3
I think that's where they usually end up!!
