Re the iPhone issue see this.
https://community.virginmedia.com/t5/Networking-and-WiFi/iOS-14-Weak-Security/td-p/4410050Have you tried a pinhole reset of the Hub to revert everything back? If not - make sure the 2 passwords on the Hub sticker are still there and legible first !
Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 10’ to stabilise - dont manually switch it off at any time.
See if that sorts it
