on 04-10-2023 17:08
My hub3 is warm and showing a red light (same as many others on this forum). I've reset it, blown out and dust but it's still doing the same. This has been constant for a couple of weeks now and has corresponded with connectivity issues (regardless of device). Can you please advise how we go about getting a new device.
on 04-10-2023 18:54
You can do the check from the Hub 3 menu.
Login at http://192/168.0.1/
Run the Network diagnostic tool
Scroll down through the results look for the Temperature entry - is it Normal or not ?
on 04-10-2023 19:15
Hello clairebeggan,
Thanks for your first post and welcome to our Community.
Sorry to hear you are having an issue with Hub3 red light
I'd like to take a look into this for you and arrange an engineers visit to swap this over
If you can check your logo at the top right of your screen that would be great.
In the mean time can you please ensure the hub is in a well ventilated place away from any direct source of heat
Gareth_L
on 05-10-2023 15:57
Thanks for the details clairebeggan.
Now we have arranged for the hub to be swapped over.
Can you please keep us posted how things are after the visit.
Gareth_L
on 12-10-2023 09:04
All fixed now. Thanks Gareth.
on 14-10-2023 09:24
Hi clairebeggan 👋
Thanks for providing an update on this. I'm glad to hear things are now resolved.
If you do need anything else, please feel free to make a new post and one of our team/community will be more than happy to help out.
