  • 6
Message 1 of 8
Hub 3 to a wifi extender unit
Hi we cannot get wifi signals in 2 bedrooms I have tried virgins wifi extenders but still not good at all could be a cable thing . I am on about buying some non inline wifi extenders and using a Ethernet cable . Will I have any issues with the new superhub 3  . With a set up or can I just plug the cable in
thanks
  • 17.33K
  • 1.82K
  • 3.01K
Message 2 of 8
Re: Hub 3 to a wifi extender unit
What do you mean by "non inline wifi extenders"? What make/models have you in mind. How are you planning to connect them to the Hub?
  • 6
Message 3 of 8
I mean my power around the house is on 2 seperate circuits and the 2 new bedrooms are new builds . I have managed to get a Ethernet cable close to them  . I need wifi in the rooms I have a speed of 200 . I am not sure which type would be on . Just to plug it into the Ethernet what goes to the hub
thanks
  • 31.35K
  • 1.63K
  • 5.48K
Message 4 of 8
if you have a ethernet cable from the hub to the rooms you need wifi in you can just attached a wireless access point to the ethernet. If you also want more ethernet ports you can add switch and connect the access point to the switch
  • 6
Message 5 of 8
sorry I am not into all these things ? Wireless access point ? What do they look like ? And where
thanks
  • 31.35K
  • 1.63K
  • 5.48K
Message 6 of 8
https://www.amazon.co.uk/s?k=wireless+access+point&ref=nb_sb_noss_2
  • 6
Message 7 of 8
I have got a wireless access point all connected and all is good BUT it has its own password which I used then all of a sudden everyone didn’t need a password I know iPhones share passwords but the Xbox also didn’t need it how can I make it secure ?
thank you
  • 24.55K
  • 1.41K
  • 3.12K
Message 8 of 8
@Jeffpea wrote:
thank you
You can change the SSID and password on the AP to that of the hub or keep it separate. That’s down to you.
