on 17-11-2023 15:26
My hub 3 has a constant red light I have tried resetting it , unplugging it everything you're told to do and it's still a red light . It's not over heated and is in an open area . Please can someone help me ! Thanks
on 18-11-2023 15:52
Hi Jodielou,
Thanks for your post and welcome to the community.
Sincere apologies for the issues faced with the Hub, so we can investigate the matter further I've dropped you a PM.
The message will appear within the envelope icon.
Regards,
on 08-12-2023 12:31
Thanks for your cooperation over PM Jodielou,
A replacement Hub should now be in place for you!
Do pop back up if you require any further assistance.
Take care,
