dobbollah
  • 16
Hub 3 red light
I've had the red light for over a week now, routers stood up, plenty of ventilation...
I've powered it off, pin hole reset.....no change.
Forum suggests a new hub is needed...
  • 3.16K
  • 248
  • 685
Re: Hub 3 red light
Red light is usually an overheating warning.  If the Hub is in any way hot, phone in and get it replaced.
Ayisha_B
  • 1.31K
  • 48
  • 131
Re: Hub 3 red light
Hi @dobbollah,
Welcome to our Community Forums and thanks for posting.
A red light on the hub would usually indicate the hub is overheating.
I will need to arrange for an engineer to come out and get this checked and replaced if needed.
Will pop you a PM now so we can get your address confirmed and the visit booked 🙂
Ayisha_B
