Hub 3 red light
I've recently joined Virgin and my service has been down more in 2 months then 5 years with my previous provider.
My hub is in modem mode and constantly has a red status light. Every now and then I lose the internet connection for hours.
The service check says my connection is fine.
Online help suggests the unit is overheating, so I put a 12inch fan next to it, but it's not helping
Other's have said the light is magenta not red and is normal, but mine definitely looks red and my service is down.
Can't get through to support. I was on hold for an hour and a half and then they just dropped my call.
Any ideas what I should do?
Tags (3)
  • 24.99K
  • 1.44K
  • 3.18K
Re: Hub 3 red light
The red light means it's in Modem Mode.
  • 17.52K
  • 1.84K
  • 3.05K
Re: Hub 3 red light
Put the Hub back into modem mode. If it stays "red" then it's overheating. If it goes white(ish) then its fine and you light really is "magenta" when in modem mode.
Also you haven't said what happens on devices connected on ethernet cable when wifi ones drop out? That is - is it really the network that is disconnecting or just the wifi?
Finally, as well as trying the “check service,” Area status webpage" (link at top right of this forum), also try the “free” Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level (that may not be listed on the Area Status web page which usually covers >1000’s of customers) - that may give you more info, but even that wont cover problems affecting just a few customers.
  • 4.46K
  • 756
  • 1.81K
Re: Hub 3 red light
@jbrennand  meant to say "put the hub back in router mode"....
Re: Hub 3 red light
Thanks for your feedback.
I'll test the router mode out tomorrow and see if it really is overheating, regarding the devices.
Everything is connected and working in my LAN (Wifi & Wired). My Asus router's web UI shows the internet is down. I can't remember what info was there or if it had a public IP. I'll check next time it happens. Is there a web UI for the Hub3 in modem mode?
Thanks for the local issues number. I'll definitely check that next time!
  • 17.52K
  • 1.84K
  • 3.05K
Re: Hub 3 red light
http://192.168.0.1 (router mode) or http://192.168.100.1 (in modem mode)
