DepeOnline
Hub 3 red light with no issue
Just as the title says I have the Hub 3, had it for like 6/7 months now with no issues. Last month the I restarted my router due to a drop in connection and when it came back on the light was a solid red.
Since then I've had a few connections issues. There has been no time when the router has overheated and it's located in an open area with lots of room to breathe. I have also factory reset the router and checked all the cables on 2 separate occasions with no change.
Based on what I've seen with similar issues on this forum I should just be able to get a replacement router but I've not had time to sit on the phone with Virgin, also I'm curious if it's possible in anyway to get the hub 4? Any help is appreciated with this. Thanks!
Matthew_ML
  • 3.56K
  • 131
  • 242
Re: Hub 3 red light with no issue
Hey DepeOnline, thank you for reaching out and I am sorry to hear you've got a red light problem.
I would like to take a look into this for you, I am gong to send you a PM.
However in the meanwhile are you okay to try these steps for me;
• Then use the power switch to turn the unit back on. The Hub should now operate normally. Thanks
Matt - Forum Team
New around here?
