Hub 3 red light permanently on
ambed68
I have a hub 3 and the red light is permanently on.
It's in a well-ventilated position and doesn't feel hot to the touch.
I've tried pin-hole reset, but it returns to red.
What should I do now?
1 ACCEPTED SOLUTION
Accepted Solutions
Paul_DN
Hi ambed68,
Thank you for joining me in a private chat and for clearing security, as advised a technician has been arranged for you, you can view and if necessary change or cancel the appointment Via your Online account, please make sure someone over 18 is present, if no one is home there will be a £25 missed appointment charge.
Please let us know how things go, if you do need any further help in the meantime, please do not hesitate to reach back out.
Paul.
3 REPLIES 3
Post up a photo and a VM Person will respond on here
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & BT sport), x3 V6 boxes (1 wired, 2 on WiFi) Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
Zach_R
Hi @ambed68,
I'm very sorry to hear of the issues you're having with your Hub 3 displaying a constant red light. If you haven't done so already, please follow each of these steps.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the issue remains following the above, please respond to the private message that I'll be sending your way shortly and we can go from there.
Zach - Forum Team
New around here? To find out more about the Community Forums, take a look at our FAQs!
Paul_DN
Hi ambed68,
Paul.
