on 03-05-2021 14:18
Hi, I have a hub 3 with a permeant red light, after reading the other posts on this is was recommended to start a new thread. The red light appear about a week back, hub is still working as normal. Have gone through all the resetting procedures with the same result. Little concerned if this warning is related to over heating?
Thanks.
Answered! Go to Answer
on 05-05-2021 12:23
Thank you for providing me with that information over PM.
I have raised this with our engineers, you can find the time and date of your appointment via your online account.
Kind regards,
Zak_M
on 04-05-2021 08:03
Tried long power down and still the same?
on 04-05-2021 08:56
on 04-05-2021 09:18
Thanks, yes its in router mode (I give up trying to get it to work just in modem mode). Hopefully a VM member will respond as trying to get through to CS is a very long painful experience.
on 05-05-2021 08:26
Anyone from VM able to help with this please? Can't get through on the phone.
on 05-05-2021 09:23
Good morning @TrueRomance.
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with the hub overheating.
We will need to get an engineer out to come and replace this, I will pop you over a PM so that I can get that resolved for you.
Kind regards,
Zak_M
on 05-05-2021 12:23
Kind regards,
Zak_M
