  • 14
Hub 3 problem
Problems with hub 2 dropping out every day and weak signal in some rooms .
When it dropped out i would need to restart then everything ok.
Received hub 3 yesterday...all fine till night and it dropped out on tv ...connected to netflix via firestick and it was fine .
Reset all today and tested for blackspots ...none ...did a speedtest and was good in all rooms .
Tried to connect to sonos ...nothing.
All showing as conmected in virgin connect app.
T.v also dropped out again on iplayer.
Any solutions ? As its not a speed problem
  • 24.7K
  • 1.42K
  • 3.14K
Re: Hub 3 problem
Are these wired or wireless connections?
  • 11.81K
  • 925
  • 1.52K
Re: Hub 3 problem
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 7.69K
  • 461
  • 486
Re: Hub 3 problem
Hi Biffobear50,
Really sorry you've been having some issues with the services as well as the delay in getting back to you, we have been busier than usual.
I've had a look at the back end of things from here and can see all is good with the hub itself. Are you still having issues now?
Can you confirm if the issues are with Wi-Fi or wired connections?
Keep us posted.
Emma_C - Forum Team
