  • 13
Hub 3 not performing
Hello Virgin Media,
My Hub 3 performance is poor. My laptop on a table about 20' away in the same room with no obstructions receives a very bad signal.
The Green WiFi light continually flashes and has done for some time. I just keep putting up with the slow internet.
On a speed test it says about 8 mbps. I have the 100mb package.
My iphone put near the hub, 3-4' away, gets a very good signal.
The ethernet slots at the back of the hub are taken with the TV, BluRay, PS4 & Hue. I do not want to lay an ethernet cable across the floor to the laptop. This is not an option.
I 'phoned VM help (150). They were no help and just keep saying that there was no problem with my devices. They refused to offer any help.
I have, several times, rebooted everything to see if that works.
I requested a new Hub be sent to me as I think mine has an undetected fault.
How can I request another Hub to see if my straight line WiFi connection performance to my laptop improves as my Hub is faulty?
I have tried calling, no help. Can I request one online?
Thanks for any assistance.
  • 11.83K
  • 925
  • 1.52K
Re: Hub 3 not performing
Try a factory reset ...
With the Hub Powered on use a paper clip or similar and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Then
Carry out a speed test at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other items connected. Post the results on here.
At the best of times Wi-Fi is a fickle beast that can be affected by numerous things such as distance from the Hub,  building construction, other electronic devices, neighbouring Wi-Fi, basically all sorts.
VM supply to the Hub, after the Hub it is up to you.
Many on here, myself included advocate the use of a third party Gigabit capable Wi-Fi router or Mesh system.
You may be as well refining your Wi-Fi management, it might not fix your problem but will certainly help keeping track of your Wi-Fi frequencies.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
Mike Robinson
  • 13
delay in replying due to Toshiba Satellite laptop refusing to boot up.
Thanks for the reply.
I have tried the suggested way of doing things but still get the flashing Green WiFi light on the router and slow speeds.
I have now logged back in to all devices and reset them but nothing seems to work.
That is why I originally asked for a new router to be sent as the one I have may have an intermittent or a fault that does not show remotely.
How can i get Virgin Media to send me a new router as I am sure this is the problem?
I have telephoned them before but they kept telling me to rebooted the system and "everything looks okay from where we are".
Please can someone at Virgin Media just send me a new router to replace mine???
Many thanks,
Richard Kerswill
