Tomd8820
  • 12
Message 1 of 16
Hub 3 no connection
I am having constant issue with no getting a connection to my hub 3 white router since a connection issue was resolved in my area today.
it was brilliant before this either intermittent signal poor speed. Connect more then one device and it would grind to holt reminiscent of dial up speeds. All it’s lacking is the whirring/screeching sound effects!
Currently I have a constant green WiFi light and a flashing green power light.
I have gone through all the check lists to be told I have no internet - thank god for that reveal, few what would I do without a state the obvious comment but alas I go through the check list as requested, believe it or not I still have no internet. Virgins only online solution - using my phones data - is to keep go through the check list and keep telling me I have no internet. Yes I’ve waited the 5-10mins - numerous times I might add
If anyone can offer me a real solution it would be greatly appreciated
For now I’m off to try remember what we did before internet
Thanks in advance
gary_dexter
  • 31.31K
  • 1.94K
  • 4.21K
Message 2 of 16
Re: Hub 3 no connection
Is the service status page showing any issues still?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 16
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 16
Can you please
Tomd8820
  • 12
Message 5 of 16
It was until 14:50 when I got this message
Virgin Media Outage Update - ID: C01168019 We're pleased to tell you this issue is now fixed. Best wishes, the Virgin Media Team
I’ve had slow/no existent internet most week and fairly regularly chalked it up to more people at home/COVID etc... but it’s got worse.
So checked my area noticed some works going on so I put my number in for alerts for when it was fixed.
I got above message at 14:50 and by 15:00 my router packed in
gary_dexter
  • 31.31K
  • 1.94K
  • 4.21K
Message 6 of 16
Has it been rebooted since the "resolution"?
Tomd8820
  • 12
Message 7 of 16
Appreciate the reply however I have no internet what so ever I am on my 4g mobile I can not get any connection to my router so can not put the 192.168.0.1 in as it just kicks back no internet!
Plus not signing up to a third party monitoring service to tell virgin something they can remote monitor themselves
Tomd8820
  • 12
Message 8 of 16
Yes it has been rebooted
Tomd8820
  • 12
Message 9 of 16
Downstream/Upstream and config all blank
this is the network log - the table hasn’t copied very well
01/01/1970 00:49:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:49:3Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:36:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:35:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:34:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:34:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:34:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:33:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:33:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:32:2Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:30:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:30:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:29:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:28:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:28:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:28:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:27:39Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:27:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:27:27Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/11/2020 12:27:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 16
It may be a good idea to carry out a factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once the lights are stabilised check your system again.
