philski69
  • 6
Message 1 of 10
Hub 3 keeps resetting
My Hub 3 keeps resetting  here is my network log for last few days
01/01/1970 00:01:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 20:09:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 18:49:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 12:02:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 00:33:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 20:11:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 18:45:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 02:08:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 20:29:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 16:04:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:00:20criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 08:57:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 08:57:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 08:57:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 08:57:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 08:54:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Done normal turn on and off even done full reset but no joy
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: Hub 3 keeps resetting
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream and Upstream tabs onto here, if you get a yellow warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
philski69
  • 6
Message 3 of 10
My BQM
13310000003.940256 qam25
22030000003.940256 qam9
32110000003.738256 qam10
42190000003.740256 qam11
52270000003.540256 qam12
62350000003.538256 qam13
72430000003.438256 qam14
82510000003.438256 qam15
92590000003.440256 qam16
10267000000438256 qam17
11275000000440256 qam18
12283000000439256 qam19
13291000000440256 qam20
142990000004.638256 qam21
153070000004.340256 qam22
16315000000440256 qam23
17323000000440256 qam24
183390000003.938256 qam26
193470000003.940256 qam27
20355000000440256 qam28
213630000003.740256 qam29
223710000003.540256 qam30
233790000003.440256 qam31
243870000003.440256 qam32
1Locked40.340
2Locked40.370
3Locked38.950
4Locked40.350
5Locked40.350
6Locked38.950
7Locked38.950
8Locked38.960
9Locked40.340
10Locked38.950
11Locked40.350
12Locked39.350
13Locked40.350
14Locked38.960
15Locked40.350
16Locked40.360
17Locked40.350
18Locked38.960
19Locked40.950
20Locked40.330
21Locked40.350
22Locked40.350
23Locked40.360
24Locked40.300
1603000004.2512064 qam1
2537000004.15512064 qam2
3462000004.1512064 qam3
4394000004.075512064 qam4
3ATDMA0000
4ATDMA0000
Had BQM set up
Beth_G
  • 3.42K
  • 212
  • 344
Message 4 of 10
Hey philski69,
Thanks for your post on the Community Forums, I'm sorry to hear you've been having some problems with your broadband service.
I've been able to locate your account and can't find anything that could be causing the issues, all of your hub specs are within the expected parameters.
Please let me know if you're still experiencing any issues and I'll be happy to help further from here.
Many thanks,
Beth
philski69
  • 6
Message 5 of 10
Hi Beth
thanks for getting in touch, since posting the resetting got worse so I ended up calling again last Thursday and the guy on the tech team ran some tests and said he would send out a new router. this arrived Saturday and I installed it as instructed only to find the house phone line didn't work. Rang up on my mobile (as no phone line) guy again said he could see a problem virgins end and they would fix it and tell me when they had. Late Saturday night I get a call to say phone lines were fixed, so I thanked them for sorting it out and letting us know then I explained the router was still resetting not as much but still doing it he ran some tests and said they would look into it. This has now been going on for over 10 weeks I have been with from the beginning when it was blueyonder and I have never had any problems until 10 weeks ago. I now see on the forum that I'm not alone with this particular problem
goodbodyj
  • 15
  • 5
Message 6 of 10
I had (maybe have, time will tell) a similar issue which started a few months back - SuperHub 3 rebooting about once a day.  Not always, but usually just before 1am.
I reset with the pin-hole button on the back of the router and it hasn't spontaneously rebooted since, about 5 days.
This also caused me to revert back to firmware 9.1.1811.401 from, I think, 9.1.1912.302.  That may or may not be relevant.
So, you could try a pin-hole reset.  I backed up my settings first and then restored after the reset.
Good luck!
philski69
  • 6
Message 7 of 10
Thanks for that Re: Hub 3 keeps resetting
Thanks for that but I have already tried that several times but no joy
horseman
  • 11.56K
  • 258
  • 1.58K
Message 8 of 10
@goodbodyj wrote:........
This also caused me to revert back to firmware 9.1.1811.401 from, I think, 9.1.1912.302.  That may or may not be relevant.........
Typically the f/w will  revert from a NMS rollout to previous “config” software Version rollout when Reset is performed. Often see the more regular naive/inexperienced Contributors (and unfortunately even some forum staff) That fail to check network log for Software install stanza’s to ensure that any “NMS” stanza’s (viz typically a hub mac specific test release) have subsequently been updated by normal CONFIG (viz production) TFTP DHCP software release.
This will/should be a familiar “gotcha” to a few here that have spent many years trialing/testing majority of VM hubs and other equipment......
It also worth (imho) checking the hardware version as well as software version as even the Hub 3 (viz VM505 Ts2492lg-VM) had more than Just v10 released.
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
DEFROCKED
DeanoB76
Message 9 of 10
Good evening,
 As many others are suffering the same issue, my Hub 3 is going through the same reset loop at least 5/6 times a day..
 Extremely annoying when trying to work from home due to the current climate and unable to do so, as the connection is constantly tripping out, with the router in a continuous boot loop..
 Any help would be greatly appreciated, and yes I’ve already tried all the usual methods of checking things over, to no avail..
Robert_P
  • 2.94K
  • 148
  • 266
Message 10 of 10
Hello DeanoB76
Sorry to hear of the broadbadn and Hub issues you're experiencing, we understand how frustrating this can be and appreciate you raising this via the forums. Welcome to the community.
From looking at your connection, everything appears to be within the spec's and ranges we'd expect. You mentioned you had followed all of the online recommendations, did this include a pin hole reset?
On the Hub there is a small hole located just below the ethernet ports on the back of the Hub, If you carefully insert something thin enough this will rest the Hub to it's factory settings, this will revert all settings to how they were when it was originally received meaning all devices and any setting changes you have made will need to be set up again.
We would also recommend setting up a BQM, you can do this for free here and let it run for 24 hours after the pin hole reset.
Let us know if this helps resolve the issue.
Rob
