look....
that white light at the bottom of the hub 3 is your main indicator....
is that flashing green - if so - it means you have lost connection with the exchange...
if it is white - you just have crap wifi in your home - look at different home netowrking options the virgin router wont help you
If you find my responses help or amuse you in any way, please cheer me up and give me some Kudos - - - - Services: Hub3 500mb speedtest.net result 22 Jan 2021 = 550mb down / 36mb up Ping 12
