  • 11.32K
  • 1.15K
  • 1.81K
Message 21 of 47
Re: Hub 3 keeps rebooting disconnecting internet - No help from support
They are not ok - you need another tech visit
  • 44
Message 22 of 47
I literally don't know what to do at this point then. Two techs visit. Two techs say the levels are right. The Hub reboots and I lose internet on a regular basis. Experts here (thanks so much!) tell me there is something wrong.
Virgin senior support/forum folks how do I actually get this fixed?
(I could also go into how "On-Demand" has not worked for us for 4+ weeks now either, techs can't fix that either aside from "opening a ticket with IT to look on the server side") - Its just a horrible, horrible experience all around. 😞
  • 44
Message 23 of 47
Heard from VM that they are sending a senior tech out on Saturday. From the latest SNR/Level data I posted above which specific ones are out of spec so I can have that conversation with them?
  • 44
Message 24 of 47
Been running BQM since last night - Don't see any issues? For the tech visit tomorrow is anyone able to call out which SNR/Level values are out of spec and need to be fixed? I'm concerned that given the BQM below the techs will just say the levels are correct again?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2db141a1a1fdf7f98f4067c0d320235318...
  • 11.32K
  • 1.15K
  • 1.81K
Message 25 of 47
All your upstream power levels are maxed out on all 4 channels.
Too many PostRS errors on every down channel.
  • 44
Message 26 of 47
I think this BQM finally clearly shows how the problem keeps impacting me right?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/48cf6edd404c0fabd13a440e1eaa49f5bc...
  • 2.33K
  • 102
  • 158
Message 27 of 47
Thanks for your post pdampier,
I'm having issues viewing your BQM as the graph doesn't appear to be visible and when selecting the option to click here, login details are required.
I'm happy to look into this further for you, please check out the purple envelope in the top right hand corner for a PM from me
Kindest regards,
David_Bn
  • 13.67K
  • 1.06K
  • 3.18K
Message 28 of 47
@David_Bn - same problem viewing BQM but surely thats secondary at most - with upstream maxed out at 51 [5.1] and connections being dropped probably due to that is it not time a tech was booked
____________________
Tony
  • 44
Message 29 of 47
Regional Supervisor visited last night and replaced Hub 3 with a new one and all connectors from outside through to cabinet and adjusted power level there.
Here are the new figures:
186750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
  • 44
Message 30 of 47
1186750000536256 qam7
21947500004.636256 qam8
32027500004.436256 qam9
42107500004.336256 qam10
52187500004.136256 qam11
62267500004.136256 qam12
72347500004.136256 qam13
82427500003.736256 qam14
9250750000436256 qam15
102587500004.436256 qam16
112667500004.537256 qam17
122747500004.836256 qam18
132827500004.837256 qam19
14290750000536256 qam20
152987500005.136256 qam21
163067500005.437256 qam22
173147500005.537256 qam23
183227500005.536256 qam24
194027500004.936256 qam25
20410750000536256 qam26
21418750000536256 qam27
22426750000536256 qam28
23434750000536256 qam29
24442750000536256 qam30
