AeitZean
Message 1 of 7
Hub 3 keeps dropping connection, appears like reboot
I really hope you can help im qt the end of my rope, i feel like we've tried everything.
What's happening is multiple times a day, out internet connection drops out (wired and wireless) and the login page doesn't work (192.168.0.1), followed by the modem light going green and the wifi and connection lights come on as if its just rebooted. This has been happening several times a day, 6 times some days, my dad needs to work from home this is not usable.
We had a tech guy (engineer?) come today, he replaced the hub 3, the splitter to the tv, the wire between, and the power supply. The hub is now plugged directly into the wall. Its still happening.
I had tried a factory reset on the old device, as well as unplugging basically everything. I've currently unplugged the phone on whim, if it happens again ill try the v6 tv box next 😞
I'll post the hub connection info, i hope someone can see something that helps. I don't want to have to find another internet provider, i don't think anyone does 100mbit in my area!
402750000
Locked
Ranged Upstream Channel (Hz)
60299815
Locked
Provisioning State
Online
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation   Channel ID
14027500004.440256 qam 30
22027500003.540256 qam 9
32107500003.540256 qam 10
42187500003.440256 qam 11
52267500003.440256 qam 12
62347500003.440256 qam 13
72427500003.440256 qam 14
82507500003.540256 qam 15
92587500003.540256 qam 1
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16030012744.3512064 qam1
23940000046512064 qam4
34620000046.5512064 qam3
45370000045.8512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID16900
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID16899
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Network LogTime Priority Description
24/06/2021 15:55:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 15:54:46Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 11:49:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 11:28:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 10:50:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 10:22:20noticeSW download Successful - Via Config file
24/06/2021 10:20:23noticeSW Download INIT - Via Config file
24/06/2021 10:20:19ErrorDisruption during SW download - Power Failure
24/06/2021 10:17:33noticeSW Download INIT - Via Config file
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
sophist
  • 2.55K
  • 420
  • 683
Message 2 of 7
Re: Hub 3 keeps dropping connection, appears like reboot
was there more data in the downstream table? you're only showing 9 channels down - there should be 24.. there should also be another table on the downstream tab with pre-rs and post-rs errors - can you post that too
AeitZean
Message 3 of 7
14027500004.540256 qam30
22027500003.740256 qam9
32107500003.740256 qam10
42187500003.540256 qam11
52267500003.540256 qam12
62347500003.540256 qam13
72427500003.540256 qam14
82507500003.740256 qam15
92587500003.740256 qam16
102667500003.940256 qam17
11274750000440256 qam18
12282750000440256 qam19
13290750000440256 qam20
142987500004.440256 qam21
153067500004.540256 qam22
163147500004.640256 qam23
173227500004.940256 qam24
18330750000540256 qam25
193707500005.140256 qam26
203787500005.140256 qam27
213867500004.940256 qam28
223947500004.640256 qam29
234107500004.440256 qam31
244187500004.340256 qam32
1Locked40.950
2Locked40.960
3Locked40.380
4Locked40.950
5Locked40.350
6Locked40.350
7Locked40.960
8Locked40.940
9Locked40.380
10Locked40.9100
11Locked40.950
12Locked40.950
13Locked40.950
14Locked40.390
15Locked40.990
16Locked40.9180
17Locked40.970
18Locked40.910
19Locked40.900
20Locked40.970
21Locked40.970
22Locked40.960
23Locked40.370
24Locked40.9100
sophist
  • 2.55K
  • 420
  • 683
Message 4 of 7
So, i can't see anything obvious wrong with your power levels, everything looks to be within spec, and there's nothign in the log that looks like a problem either..
can you set up a BQM - once set up, find the Live Graph and click "Create Sharing Link" - post that back here.
AeitZean
Message 5 of 7
I set one up just before the last crash. I didn't realize it could be shared. You can see a spike of 100% packet loss when it last crashed. Thanks for responding
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e0281c415f9b8fb51ff6cd9ffefc91fe90c79459
Ike4life98
  • 25
Message 6 of 7
It seems to be a general problem. Apparently mine has been going on for 2 months and everything’s been tried. 3 different engineers have come , replaced the hub, given me an intelligent wifi pod and after all this time still happening. I asked a colleague who lives in the same area as me what provider she has and she said virgin and they are having the same problems. I live in east Hunsbury, Northampton and I’m tired of it all! I think it’s time I move on. Been with virgin for 4 yrs and now this!!
Tom_F
  • 3.42K
  • 208
  • 441
Message 7 of 7
Hi AeitZean, thanks for getting in touch.
I'm sorry to hear about the issues you've had with your connection. It's disappointing to hear that the previous engineer visit wasn't successful despite all of the action that was taken.
There's nothing of concern in the hub-logs but I appreciate the BQM doesn't look great. I'd like to look further into it for you, but wasn't able to do so using your forum details alone on this occasion - so please look out for my PM (the purple envelope) and get back to me when you can.
Tom
