on 12-11-2023 14:40
Hi my mum's Hub 3 keeps losing ethernet connection or basically stays on wifi. This has been going on for at least 2 years i think. In that time i have VM come and check outside connections, change to a new hub 3 and remove the filter that was connected as it wasn't needed. I've done factory reset, tried different PC's and cable changes but the issue is still there. She's paying for a service that is not delivering as attended.
on 12-11-2023 15:42
Post the power levels, Pre and PostRS errors and network log from the Hub.
Also setup a BQM to monitor your circuit www.thinkbroadband.com/ping
Once done we can comment.
on 12-11-2023 17:37
As Adduxi says - follow this procedure on your mums Hub
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 13-11-2023 00:22
Hi here is the info.
1 | 203000000 | 5.4 | 40 | 256 qam | 9 |
2 | 139000000 | 5.4 | 40 | 256 qam | 1 |
3 | 147000000 | 5.5 | 40 | 256 qam | 2 |
4 | 155000000 | 5.4 | 40 | 256 qam | 3 |
5 | 163000000 | 5.5 | 40 | 256 qam | 4 |
6 | 171000000 | 5.5 | 40 | 256 qam | 5 |
7 | 179000000 | 5.5 | 40 | 256 qam | 6 |
8 | 187000000 | 5.5 | 40 | 256 qam | 7 |
9 | 195000000 | 5.4 | 40 | 256 qam | 8 |
10 | 211000000 | 5.3 | 40 | 256 qam | 10 |
11 | 219000000 | 5.3 | 40 | 256 qam | 11 |
12 | 227000000 | 5.1 | 40 | 256 qam | 12 |
13 | 235000000 | 5 | 40 | 256 qam | 13 |
14 | 243000000 | 5 | 40 | 256 qam | 14 |
15 | 251000000 | 5 | 40 | 256 qam | 15 |
16 | 259000000 | 5 | 40 | 256 qam | 16 |
17 | 267000000 | 5 | 40 | 256 qam | 17 |
18 | 275000000 | 4.9 | 40 | 256 qam | 18 |
19 | 283000000 | 4.8 | 40 | 256 qam | 19 |
20 | 291000000 | 4.8 | 40 | 256 qam | 20 |
21 | 299000000 | 4.9 | 40 | 256 qam | 21 |
22 | 307000000 | 4.8 | 40 | 256 qam | 22 |
23 | 315000000 | 5 | 40 | 256 qam | 23 |
24 | 323000000 | 4.9 | 40 | 256 qam | 24 |
1 | Locked | 40.9 | 44 | 0 |
2 | Locked | 40.3 | 13 | 0 |
3 | Locked | 40.9 | 10 | 0 |
4 | Locked | 40.3 | 10 | 0 |
5 | Locked | 40.3 | 12 | 0 |
6 | Locked | 40.3 | 18 | 0 |
7 | Locked | 40.9 | 17 | 0 |
8 | Locked | 40.3 | 25 | 0 |
9 | Locked | 40.3 | 40 | 0 |
10 | Locked | 40.3 | 44 | 0 |
11 | Locked | 40.3 | 46 | 0 |
12 | Locked | 40.3 | 69 | 0 |
13 | Locked | 40.3 | 60 | 0 |
14 | Locked | 40.3 | 67 | 0 |
15 | Locked | 40.3 | 67 | 0 |
16 | Locked | 40.3 | 49 | 0 |
17 | Locked | 40.3 | 45 | 0 |
18 | Locked | 40.3 | 40 | 0 |
19 | Locked | 40.3 | 42 | 0 |
20 | Locked | 40.3 | 52 | 0 |
21 | Locked | 40.3 | 73 | 0 |
22 | Locked | 40.3 | 40 | 0 |
23 | Locked | 40.3 | 56 | 0 |
24 | Locked | 40.3 | 60 | 0 |
1 | 49600000 | 45 | 5120 | 64 qam | 1 |
2 | 36600000 | 44.5 | 5120 | 64 qam | 3 |
3 | 30100000 | 44.3 | 5120 | 64 qam | 4 |
4 | 43100014 | 44.8 | 5120 | 64 qam | 2 |
5 | 23600000 | 44 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 2 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 13-11-2023 00:23
13/11/2023 00:14:38 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/11/2023 00:14:27 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/11/2023 00:13:48 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/11/2023 00:01:46 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 16:04:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 14:04:6 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 14:03:54 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 14:02:42 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 14:01:46 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 01:32:58 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 01:32:39 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 01:31:15 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/11/2023 01:31:3 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/11/2023 01:57:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2023 23:25:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2023 16:11:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2023 13:39:15 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/11/2023 01:33:8 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/11/2023 01:28:12 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 13-11-2023 15:46
Stats all good - a few Up T errors - buy may be historic accumulation - keep checkin to see if they increase.
Lets the BQM - "share live link" as soon as - as that will reveal any network dropouts on ethernet devices rather than just wifi interference.
on 14-11-2023 11:25
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/aab34bb969a63a923501df46499694439448de78-14-11-2023">My Broadband Ping</a>
on 14-11-2023 14:33
BQM shows no signs of the circuit dropping. Not much wrong that I can see. Hopefully VM can diagnose better from their side. If it's the ethernet dropping, it could be a faulty Hub but you have had this replaced. It could also be something in the property causing this? Are you using any switches, powerline adapters etc. etc. ? Is the Hub sited near anything electrical, e.g. fridge, TV, microwave ?
on 14-11-2023 17:01
Hi, all the stuff you mentioned is a no and so i'm guessing it could be a faulty Hub but then again i live in the next road and never experienced this issue.
on 15-11-2023 14:46
Hi i chatted to VM over Whatsapp about the Hub no help at all they gave me a number Gadget Rescue Team instead.
