28-02-2022 07:18 - edited 28-02-2022 07:19
PERMENTANT RED LIGHT ON FRONT
So on my hub 3 the power light that's normally red has been permanently red for a while now. I'm having to reset the hub daily due to connection issues.
Going away from that issue I'm not sure if it's a faulty bit of kit but I get weaker signal in the next room. And zero signal upstairs on the far side of the house. I know this can be related to the size of the house/ device location etc but it's not that far to be honest.
It's more the first issue with the red light i wanted solved. Thank you in advance.
on 28-02-2022 07:50
the light is magenta that can be seen as red in modem mode - is it red in router mode or white - that can be dirty white to coffee coloured
if it is red in router mode then the hub wants replacing - if its just changed colour in modem mode then it is fine
normal advice it to turn it off in router mode for a few minutes and if it comes back with a red light it wants changing
so confirm that and then wait for VM if it does have a red light
on 28-02-2022 09:12
on 28-02-2022 09:46
Hi Tony,
Firstly thank you for the advice and I've logged in to check and its router mode. And to answer the MOD below.
on 28-02-2022 09:47
Thank you, I've replied to Tony with a pic.
on 02-03-2022 09:50
Thanks @LeeMac89
I am going to send you a private message so we can arrange a new hub for you.
Please look out for the purple envelope in the top right of the page and pop me a reply when you can.
Vikki - Forum Team
