Eddie98
  • 62
Dialled in
Hub 3 into modem mode & TV360 connection
The cable socket in our house is close to the TV and the Hub3 is connected by a short cable, so I am very limited in being to position the Hub3 away from the TV and TV360 box. Having tried various ways to try and improve wifi speed and reliability I am considering changing my Hub3 to modem mode and connecting it to a dedicated router which I can then position to improve wifi coverage.
If I do this do I also need to reconnect the master TV360 box, currently connected to the Hub3 by ethernet, to the dedicated router instead?
Tags (3)
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Re: Hub 3 into modem mode & TV360 connection
@Eddie98 wrote:
Yes. In modem mode everything connecting over Ethernet needs to go into the 3rd party router.
