Settling in
Hub 3 intermittently losing connection / restarting
For the past week or so my hub 3 has been randomly dropping connection or restarting (not sure how to tell the difference).  I have done a factory reset and swapped it from router mode to modem only mode.
I started to write down the times it happened while it was in use:
Sat  - 20:30, 20:59, 21:08, 21:49
Sun - 21:45, 22:57
I have started running BQM and this is the graph so far:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d72fb5ab0c6bfbcae42843ad5e947a3dc4...
The status of the router is below:
14750000008.438256 qam33
22190000009.540256 qam11
32270000009.540256 qam12
42350000009.540256 qam13
5243000000940256 qam14
6251000000940256 qam15
72590000009.340256 qam16
82670000009.440256 qam17
9275000000940256 qam18
102830000009.140256 qam19
112910000008.938256 qam20
122990000009.440256 qam21
133070000009.340256 qam22
143150000009.140256 qam23
153230000009.140256 qam24
164110000008.940256 qam25
174190000008.840256 qam26
184270000008.640256 qam27
194350000008.538256 qam28
204430000008.540256 qam29
214510000008.340256 qam30
224590000008.440256 qam31
234670000008.638256 qam32
244830000008.940256 qam34
1Locked38.920
2Locked40.910
3Locked40.340
4Locked40.380
5Locked40.320
6Locked40.990
7Locked40.380
8Locked40.370
9Locked40.390
10Locked40.310
11Locked38.980
12Locked40.3240
13Locked40.370
14Locked40.380
15Locked40.380
16Locked40.3170
17Locked40.3250
18Locked40.360
19Locked38.9110
20Locked40.350
21Locked40.3140
22Locked40.340
23Locked38.9100
24Locked40.320
1603000004.225512064 qam6
2462000784.125512064 qam8
3394000004.1512064 qam9
4537000004.175512064 qam7
3ATDMA0000
4ATDMA0000
Settling in
Re: Hub 3 intermittently losing connection / restarting
17/08/2020 07:48:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 21:56:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 21:00:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 20:44:10Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 20:44:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 20:44:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 17:28:43Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 17:28:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 17:28:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 17:28:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 15:12:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 15:12:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 15:12:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 15:12:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 09:40:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 09:39:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 09:39:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 09:39:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 05:47:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Settling in
Apologies the error log was so long I needed multiple messages.
Any help would be appreciated!
  • 6.5K
  • 487
  • 857
Hero
How are you connecting your device, Wi-Fi or ethernet cable ?
Your Hub stats are OK, the Downstream Power Levels are quite high but still well within spenc.
Apart from the full height red band late last night your BQM is looking as good as it can be.
Keep a record of the drop outs to see if they align with anomalies on the BQM.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Settling in
I have a windows 10 pc connected via ethernet cable, and than various other devices connected via wifi. Everything drops out at the same time.
It is reassuring to know everything looks fine. The connection is working perfectly apart from these dropouts.
I will leave the BQM running and keep writing down the dropout times.
Thanks.
  • 2.95K
  • 165
  • 275
Hey there DrMKLewis,
I've tried to take a quick look at your network details but the Hub seems to be offline or I may be looking at the wrong account so haven't been able to post back my findings. Please do keep monitoring your connection and let us know if you experience further connection issues.
Lisa
