  • 7
Message 1 of 12
Hub 3 has solid red power light
My Hub 3 has a solid red power light.  It is not in modem mode.
It's not hot and is in an open area with nothing blocking the vents (and has been since I first had it).
Diagnostic test says the Hub temperature is normal and reports no other issues.
I have tried switching off the power for 45 mins to ensure the Hub is 'cold' then restarting but after boot up the power light is solid red again.
Wireless and ethernet connectivity are fine at the moment.
I've had the Hub for a few years now so could simply be on it's last legs.
Any help much appreciated.
Teresa
  • 11.56K
  • 823
  • 1.64K
Message 2 of 12
Re: Hub 3 has solid red power light
Is it working though?
I work for Virgin Media and my posts are my own opinions
  • 4.36K
  • 742
  • 1.77K
Message 3 of 12
Clearly it isn't working as there's no properly functioning status LED.  I've flagged it for the forum staff to advise
  • 7
Message 4 of 12
As I said, yes ethernet and wireless connectivity are both fine at the moment.
All the advice I've read says not to ignore this though.
Cheers,
Teresa
  • 4.36K
  • 742
  • 1.77K
Message 5 of 12
Certainly not.  If there's no outward sign of overheating then it still needs replacing, but it's probably OK to keep using it in the meanwhile, but I wouldn't leave it on overnight or if you're out of the house for extended periods.
Forum staff will respond in due course, but they're a tad stretched at the moment.  But probably still as quick to get you a replacement as if you endure the misery of trying to telephone it in (not to mention, as it's "off-script", there's a chance the agent will tell you that it's fine, and nothing needs to be done).
  • 7
Message 6 of 12
Thank you.  😊
I did try calling but couldn't stand the hold music beyond 15 minutes, lol!
  • 1.36K
  • 72
  • 138
Message 7 of 12
Good afternoon @TeresaSadler
Welcome to the forum and thank you for taking the time to post.
I am sorry to hear that you are having issues with your hub. As advised previously we are going to need to replace the hub. I have taken this opportunity to book this for you, It will be with you in the next 3-5 business days.
Kind regards,
Zak_M
  • 7
Message 8 of 12
Thank you Zak.  Much appreciated!  👍
  • 1.36K
  • 72
  • 138
Message 9 of 12
No problem at all,
I will pop back on Monday and see how things are going.
Kind regards,
Zak_M
  • 1.36K
  • 72
  • 138
Message 10 of 12
Good morning @TeresaSadler
Just checking in, did you receive the hub 3?
Kind regards,
Zak_M
