Centaur59
  • 5
Message 1 of 10
Hub 3 green scream
I am on a VM M350 broadband only deal. The problem I have is the hub 3 WiFi cutting out. When it does this, the WiFi icon is solid green and the power light, white. After a few minutes the connection is restored.
VM service check reveals no fault. Usual advice,  reboot, factory reset. But it keeps happening.
Help!
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 2 of 10
Re: Hub 3 green scream
do you have any wired devices do they cut out
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
you DO need to sign in on hub4
____________________
Tony
Centaur59
  • 5
Message 3 of 10
Thanks for the quick response.
Typed in the numbers.
Get welcome back message only option is to sign in to view or modify hubs settings.
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 4 of 10
you should not need to sign in - click on message below sign in box - however you can sign in and its all there as well
Tony
Centaur59
  • 5
Message 5 of 10
Found it.
Downstream ch 347000000
Upstream ch 39400036
Both locked
State online
Wired Internet fine
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 6 of 10
much more than that needed - all pages - 24 channels for downstream plus second page and 4 channels for upstream
Tony
Centaur59
  • 5
Message 7 of 10
Looking in the log, have loads of:
No ranging response received.
Unicast ranging received abort response.
All listed critical.
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 8 of 10
they may or may not be important but the levels are needed first - post the log as well
Tony
Centaur59
  • 5
Message 9 of 10
Downstream.
1 347000000
2 20300000
3 211
4 219
5 227
6 235
7 243
8 251
9 259
10 267
11 275
12 283
13 291
14 299
15 307
16 315
17 323
18 331
19 339
20 355
21 363
22 371
23 379
24 387
Upstream.
1 39400036
2 25800058
3 32600022
4 46199954
Upstream bonded.
1 ATDMA
2  ATDMA
Primary Downstream flow.
Max 402500089
Max T Burst 42600
Min traffic rate 0
Primary upstream.
MTR 38500089
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 10 of 10
Post the logs requested retaining the table formatting.
