Hub 3 green flashing power light
We are new customers and just got a hub 3.0 had someone come install it and after a week or two we have had a green flashing power light and a solid green WiFi light tried resetting and rebooting and checking wires but nothing will change it does anyone have any idea!!!!!!!
Tags (1)
  • 24.28K
  • 1.39K
  • 3.09K
Re: Hub 3 green flashing power light
What does the service status page say?
All is fine on the service status
  • 13
Any kind of green light indicates an issue with install and is usually solved by doing a pin hole reset on the back of the hub. Failing that, you will need to either live chat or call into broadband faults so they can check the system
