Mark_W1
  • 12
Message 1 of 14
Hub 3 dropouts occurring multiple times per day
I made a post on here some months ago about an issue I was having -
https://community.virginmedia.com/t5/Networking-and-WiFi/Internet-cutting-out-multiple-times-a-day/m...
Not too long after the post the issue seemed to sort itself, however it has returned. One strange thing I have noticed is that the dropouts seem to be occurring when a plane flies overhead which leads me to believe there is some kind of interference.
i still have the same bqm set up from the first time I was having these issues
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0425cba0fbcf8031ce5756e3562f906135...
I will leave the network data in the next few replies
Mark_W1
  • 12
Message 2 of 14
Re: Hub 3 dropouts occurring multiple times per day
11390000002.240256 qam1
21470000002.438256 qam2
31550000002.540256 qam3
41630000002.740256 qam4
51710000002.440256 qam5
6179000000240256 qam6
71870000001.238256 qam7
8195000000038256 qam8
9203000000-0.438256 qam9
10211000000-138256 qam10
11219000000-0.738256 qam11
12227000000-1.237256 qam12
13235000000-1.438256 qam13
14243000000-2.238256 qam14
15251000000-338256 qam15
16259000000-3.538256 qam16
17267000000-3.538256 qam17
18275000000-2.738256 qam18
19283000000-1.538256 qam19
20291000000-0.738256 qam20
21299000000038256 qam21
223070000000.740256 qam22
23315000000140256 qam23
24323000000140256 qam24
1Locked40.360
2Locked38.960
3Locked40.350
4Locked40.940
5Locked40.340
6Locked40.350
7Locked38.9190
8Locked38.950
9Locked38.940
10Locked38.9180
11Locked38.6380
12Locked37.6180
13Locked38.9190
14Locked38.9200
15Locked38.9610
16Locked38.6620
17Locked38.620
18Locked38.970
19Locked38.9390
20Locked38.940
21Locked38.690
22Locked40.350
23Locked40.360
24Locked40.340
Mark_W1
  • 12
Message 3 of 14
14620000048.5512064 qam3
23940000047.8512064 qam4
35370000049.8512064 qam2
43260000047.3512064 qam5
3ATDMA0000
4ATDMA0000
Mark_W1
  • 12
Message 4 of 14
18/05/2022 05:57:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2022 01:13:21criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2022 00:33:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 16:39:0criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 16:28:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 14:03:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 13:40:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 13:07:22criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 12:50:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 11:26:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 09:39:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 06:06:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 03:58:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 01:44:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2022 00:44:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2022 21:09:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2022 21:01:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2022 15:06:8criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2022 14:58:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2022 13:02:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 35.11K
  • 3.42K
  • 6.68K
Message 5 of 14
Stats all look good but BQM is poor.
So, is the hub in normal router or modem mode?
What other equipment have you got connected directly to the Hub/router on ethernet cables
Mark_W1
  • 12
Message 6 of 14
The hub is in router mode and the only devices connected by Ethernet cable is a Xbox and TiVo box
In the 24 hours since I have reset the hub you can see a significant amount of post rs errors appearing in channel 1
1Locked38.9338335239
2Locked40.32758383
3Locked40.31553306
4Locked40.31912227
5Locked40.31548288
6Locked40.3690428
7Locked38.91377280
8Locked38.91810293
9Locked38.91184270
10Locked38.91586217
11Locked37.61774236
12Locked37.61330232
13Locked38.93182823
14Locked38.93072801
15Locked38.9161794
16Locked38.6104620
17Locked38.9138533
18Locked38.999917
19Locked38.918429
20Locked40.31120
21Locked38.91070
22Locked40.3640
23Locked40.3480
24Locked40.3620
  • 35.11K
  • 3.42K
  • 6.68K
Message 7 of 14
Yep... lets see if VM can see any issues - I will ask them to look
Alex_RM
  • 7.24K
  • 367
  • 547
Message 8 of 14
Hi Mark_W1,
Thanks for posting, and sorry you're still experiencing some issues with the service.
Looking at things from our side it does look like a few of the hubs levels are out of specification, so I can arrange a technician for you I'll need to confirm a few details first.
I've popped you over a private message (purple envelope, top right hand corner)
Alex_Rm
Mark_W1
  • 12
Message 9 of 14
I had a tech out  who replaced the hub and installed a new cable, however the dropouts seem to still be happening. I think he mentioned that the issue was likely on the outside of the house if it wasn’t fixed.
BQM on new hub - https://www.thinkbroadband.com/broadband/monitoring/quality/share/b037951e956ab5d6c7a65aac8a91bbd313...
Matthew_ML
  • 3.62K
  • 133
  • 242
Message 10 of 14
Hey Mark_W1, thank you for reaching back with an update. I am sorry to hear this issues is still happening.
What I am going to do is send you a PM so I can investigate  this issues for you.
Please can you look out for the purple envelope as I am going to send you a PM. Thanks
Matt - Forum Team
New around here?
