Simonashley89
  • 7
Message 11 of 13
Re: Hub 3 continually drops out - Please help
apologies, I didn't explain myself very well then. I meant when I'm in the wireless signal section changing the settings. my 2.4 is on channel 11 I believe and my 5ghz is on channel 36. Should I adjust those channels or just leave them be?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 12 of 13
You need to use an analyser to see which channels are the most congested then change yours accordingly.
I use inSSIDer on my PC and >> THIS << on my android phone.
wifi-analyser-2
Simonashley89
  • 7
Message 13 of 13
will give all this a go later and see how I get on ... many thanks 🙂
