  • 5
Message 1 of 10
Hub 3 continually dropping out
For as long as I can remember ive had problems with the hub 3 dropping out. How do I upgrade to the hub 4? I've tried calling however can't get through to anyone.
  • 11.7K
  • 913
  • 1.51K
Message 2 of 10
Re: Hub 3 continually dropping out
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 24.55K
  • 1.41K
  • 3.12K
Message 3 of 10
What’s dropping out exactly?
The Hub4 is notorious for having more bugs and issues.
  • 5
Message 4 of 10
The majority of the time things work fine however at various points in the day the Internet will just drop off. My cameras and various other devices drop off and then reconnect a few minutes later. My son notices the most when playing on his pc. I really started to notice this happening more often since March (start of covid).
I have the hub 3 and M200 Fibre Broadband. When devices plugged directly into the router the dropout barely happens.
  • 24.55K
  • 1.41K
  • 3.12K
Message 5 of 10
Wired device drops barely happen or never at all?
Theres a big difference when it comes to diagnosing the issue at hand.
  • 5
Message 6 of 10
My son has just informed me that it doesn't drop out when wired
  • 24.55K
  • 1.41K
  • 3.12K
Message 7 of 10
Then I’m going with the poor WiFi output from the hub.
In that case the only logical advice that can be provided is to look into getting your own router or mesh system.
  • 5
Message 8 of 10
Thanks,  would the hub 4 be better than the 3?
I was actually looking at the Netgear Nighthawk mesh mk63 whole home wifi 6 System (on deal at costco). Would this help?
  • 24.55K
  • 1.41K
  • 3.12K
Message 9 of 10
No the Hub4 is worse.
If you go the mesh/router “route” you’ll be running the virgin hub in modem mode anyway.
The system you mention would certainly resolve all your WiFi woes.
  • 5
Message 10 of 10
