newj9826
Message 1 of 7
Hub 3 constantly updating
Ok, so I've seen a few posts relating to this issue, but I can't find any that reach a resolution so I'm starting a new one. I've had increasing issues with what I thought was wi-fi connectivity over the past few months. However, after putting the hub 3 in modem mode and connecting a router I know works well, I've seen that my hub 3 is running (or attempting to run) an update typically 2 or 3 times a day. This may take anything from 10 minutes to 30 minutes, during which time I have no internet connection. The hub internet light flashes (green) and the base light is green. Once it stops and returns to normal (magenta base light as I'm in modem mode) everything is fine. In fact the wi-fi signal strength and speed are generally pretty good. I've not looked into error logs etc etc at this point - or contacted VM yet - but I figure its either a faulty router, or something is happening externally in the network which shouldn't be. Any chance this is connected to the Intelligent wi-fi updates rolled out earlier this year? Anyway, useful to hear of anyone else experiencing the same problem and any fixes you've tried. Thanks!
  • 6.58K
  • 511
  • 1.1K
Legend
Message 2 of 7
Re: Hub 3 constantly updating
You say you already running in modem mode, therefore intelligent WIFI in the hub has nothing to do with your problems. Please post your up/downstream stats and network log.
newj9826
Message 3 of 7
Here you go:
  • 6.58K
  • 511
  • 1.1K
Legend
Message 4 of 7
Upstream power levels are too high. You need a technician to rectify, call customer services.
  • 2.31K
  • 143
  • 593
cje85
Problem sorter
Message 5 of 7
Yep, this isn't anything to do with updates, the hub is just losing the connection due to problems on the upstream.
newj9826
Message 6 of 7
Ok thanks for looking. And just so I'm not fobbed off when I call, where is the 'system' is the likely problem?
  • 1.42K
  • 79
  • 112
Message 7 of 7
Hi newj9826,
Thanks for your post and welcome to the community.
I'm sorry to see that you're having problems with your upstream power levels, but don't worry it's something I can help with 🙂
I'll need to get someone out to get it fixed so i'll pop you a private message to take some details.
Melissa
