Hub 3 constant red power light
High - I have constant red power light on hub 3. Hub is not in an area which would cause overheating. Tried hard re-set and checked cables. No wi if or Ethernet connection although reported issues in area
  • 11.58K
  • 898
  • 1.48K
Re: Hub 3 constant red power light
Are you in Router Mode or Modem Mode ?
If in Router Mode the red power light is an indication of over heating and most not be ignored.
Do not be fobbed off with "if it is cool it will be OK" or "Just blow a fan over it", this is dangerous advice.
When you go out or retire for the night ensure that the Hub is unplugged from the mains.
The only fix is a replacement Hub.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Thanks for the feedback Mike ! Not sure re: mode as I can’t access the router setting via Ethernet or wi fi. Txted the help number but the Robot interpreted “Hub 3 constant Red power light” as I need help with my mobile SIM 😳 Ah well, watch this space 👍
  • 11.58K
  • 898
  • 1.48K
If you can see the Hub using Wi-Fi it is in Router Mode.
Mike Robinson
