  • 9
TKJ
Message 1 of 8
Hub 3 connection issues
Engineer installed new VM hub 3 in December. Just got email stating VIrgin have supercharged my Hub 3 with intelligent WiFi. Tried to install app, but realised there is no sticker on Hub 3, so no settings password, which is needed in order to set up the app. At a loss what to do now. I assume engineer did not put sticker on box?
  • 10.74K
  • 1.09K
  • 1.71K
Message 2 of 8
Re: Hub 3 connection issues
The sticker on the Hub3 should be on its base. Not there ? There is also a drawer with a card - but I think that just has the wifi details on it.
  • 4.98K
  • 350
  • 846
Roger_Gooner
Superstar
Message 3 of 8
You cannot install apps on the hub. You are referring I think to the Virgin Media Connect app which runs on mobile phones and tablets with Android 5.0 or later and iOS 9 or later.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 4.41K
  • 502
  • 1.44K
Message 4 of 8
The stickers are placed on the hubs when they are made, usually on the bottom, not by the engineer who visited you.  Where did you look to get the wireless SSID and password for the hub?  The settings password is usually in the same place as those settings.
______________________
Scott
My setup: Vivid 200 Optical fibre with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Click to learn more about VIP
Use Kudos to say thanks
  • 9
TKJ
Message 5 of 8
DSC_0152.JPGThis is what I have. Do you think I am missing the correct label?
  • 834
  • 38
  • 72
Message 6 of 8
Hi TKJ,
Thanks for getting in touch.
Have you managed to locate the details needed to set up the connect app?
Hetty_R
  • 4.41K
  • 502
  • 1.44K
Message 7 of 8
The third pic you posted is a label on a TV box and has been rejected by the mods to protect your privacy as it showed the MAC address of the box.
The label you are looking for with the settings password should be located on the bottom of your VM hub. The label you posted above is one for you to put somewhere safe if you need to look up your wireless network settings, so that you don't need to turn your hub upside down.
Scott
  • 1.82K
  • 179
  • 427
vircom
Super solver
Message 8 of 8
It is on the bottom of the hub, not on the paperwork. It is factory fitted and not supplied by the installer.
