Hub 3 conflicting settings
Scott1004
Hi There.
i am hoping you might be able to help me. Everything was working fine till I upgraded today to the new booster pod. Followed all the instructions.
When I then went into my Virgin Connect App the pod was showing but got a message to say "Conflicting settings"
It then gives me 2 Network names which are both the same and when I try to apply changes I get "oops something went wrong message"
Before I had 2 separate network names and now their appears to be one network name which appears twice in the conflicting settings message
Appreciate any help you can offer.
1 REPLY 1
Legend
The frailty of the VM Connect app strikes again !
Connect to the Hub at http://192.168.0.1/ login to the menu and make configuration changes needed.
