on 10-01-2023 21:50
On the virgin media connect app I cannot connect to the hub as stating conflict settings and proving two options
WPA-WPA2 Personal or WPA2-Personal.
choosing either and the app respond oops something went wrong and suggest contacting support.
checked on the hub and WPA2-PSK which is not an option in the mobile app.
any guidance welcomed
on 10-01-2023 22:15
on 10-01-2023 22:20
these are the options in the VM connect app as cannot connect to the hub.
on 13-01-2023 11:38
Hi maconmac,
Thank you for your post. I'm very sorry to hear about the issue with connecting to the hub 3.
To confirm, have you amended any of the settings on the hub?
^Martin
on 13-01-2023 11:54
Hi Martin,
The Network Name and password where changed a long period prior to this error message appearing.
the box has been rebooted. I cannot put my finger on any specific activity that has led to this message appearing in the app.
thank you
nick
on 15-01-2023 13:04
Can you try deleting the app, rebooting your hub and then re-installing to see if this changes anything within the app?
on 15-01-2023 18:00
Thankyou, will do and will let you know.
cheers
on 16-01-2023 18:51
How did you get on? I have the exact same issue
on 20-01-2023 07:49
Hi, thankyou for your advice and apologies for the delay in responding.
I have rebooted and left off for a few minutes. I deleted the app.
tirned the hub back on and waited for it to set up and then reinstalled the app.
same problem!
next I will turn off the power boosters and try again. Seems all very complex jus t to get Wi-Fi managed in the house.
on 22-01-2023 09:18
Morning maconmac,
Thanks for trying a reboot and uninstalling things, sorry to hear there is still an issue.
Let us know when you've tried powering off the boosters.
Alex_Rm
