Edp22
  • 31
Message 1 of 28
Hub 3 and rubbish wifi
So as we enter the second weekend of dire service and ZERO contact from virgin operatives I’m wasting my Sunday evening trying to sort out ultimate oomph kit for which I pay over a hundred quid a month
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Message 2 of 28
Re: Hub 3 and rubbish wifi
What problems are you trying to fix?
Edp22
  • 31
Message 3 of 28
Two fold
speed into the house somewhere near the oomph 600mbs I pay for and inside the house WiFi coverage I can use for work and an app which sees my devices
I’ve been working fine for a year but something catastrophic happened a couple of weeks ago and it’s been awful
full day of video calls fir work today and crappy coverage
Serena_C
  • 800
  • 38
  • 81
Message 4 of 28
Hi @Edp22
Thank you for your post regarding the issues you are experiencing with your WiFi, I'm really sorry to hear you are experiencing these connection issues. I understand how frustrating that must be.
I have checked your account and can see that additional Intelligent WiFi Pods are on their way to you now to help with your coverage.
May I ask what lights are showing on your Hub 3?
Best wishes,
Serena
Edp22
  • 31
Message 5 of 28
Ultimate oomph speed
Morning again Serena
I understand your colleague Sophie has arranged for two additional pods to be delivered though I’ve had no confirmation  from your courier
sadly the speed into the house to enable the WiFi is still an issue and already today on my conference calls I’ve had to switch off the camera and pause other household devices. Can you please update me on the resolution to the actual service to the property as well as the mesh extension within ?
thanks
Tags (3)
  • 23.79K
  • 2.52K
  • 4.31K
Message 6 of 28
Re: Ultimate oomph speed
The speeds coming into the Hub have to be measured on a device connected directly to the Hub by ethernet cable and not on wifi. Is that how you are testing speeds?
Edp22
  • 31
Message 7 of 28
Your engineer did when he visited two weeks ago. Your system should have his report.  He left saying “it’s very slow sir” after going to the street cabinet and “turning it up”. Which should be impossible as I get your fastest speed available according to your marketing and my bills
thanks
  • 23.79K
  • 2.52K
  • 4.31K
Message 8 of 28
As my "Sig" says..... I am not a VM employee so have no "system" for reports 🙂
So can you do a speed test on an ethernet connection to see if they match the speeds you should be getting. If you dont want to that's ok.
The Pods ought to deliver you the correct speeds over wifi. But if its still slow then there may be a connections issue somewhere, although I am assuming that the VM staff have looked at you connection details and think it is all in spec. Has someone actually said that to you (other than the Tech)?
Steven_L
  • 5.28K
  • 369
  • 536
Message 9 of 28
Hi @Edp22,
As @jbrennand has said, your connection has been checked and everything is with the correct specifications and the pod(s) that are on their way should restore your connection to the correct speed.
Would you be able to do the checks that have been suggested?
Regards,
Steven_L
Edp22
  • 31
Message 10 of 28
Hi again
sorry didn’t read your signature anyhow I’ll wait for the new pods get them set up and stable and then plug the laptop Ethernet into the hub to run speed test   Virgin are monitoring for 30 days though per their contract terms
thanks anyhow
