  • 7
Message 1 of 5
Hub 3 alternative
is there an alternative to the Hub3, it is fine with a few devices connected however once I have 10+ devices connected the speeds and signal seems to become poor, if I switch some devices off then it gets better again
  • 24.57K
  • 1.41K
  • 3.12K
Message 2 of 5
Re: Hub 3 alternative
Put it into Modem Mode and connect your own purchased router
  • 4.36K
  • 742
  • 1.77K
Message 3 of 5
Yes.  Buy any router or mesh wifi system of your choice, stick the hub in modem mode, job done.  Many of us have done so, but not knowing your situation I'll refrain from recommendations now.
However, before spending the £70-300 on a suitable setup, be sure that this is a router/wifi problem that you have, not a dodgy cable connection.  Otherwise you can spend any amount you like on wifi gear and it won't improve matters much.
  • 1.88K
  • 95
  • 175
Message 4 of 5
Hi iancarr2020, thanks for posting.
Sorry to hear you're having issues with your WiFi.  I would like to take a closer look at this on your behalf. To enable me to do so, I am going to send you a private message.  Please look out for the purple envelope in the top right of your screen.
Lee_R
  • 7
Message 5 of 5
thnx
