sixtieskeith
Hub 3 - Solid red light
Hi all, noticed about a week ago my hub started displaying a solid red light. I didn't think much of it until I started getting the odd WiFi drop out so upon looking it up I was concerned it was connected to a possible overheating issue.
Following advice I'd seen already posted on the forum I reset the hub and tried leaving it unplugged for quite a while but it still shows the solid red light. The hub itself is about 2 years old and I've never had any problems before now. Also worth noting apart from the occasional dropout on WiFi it works 100%. Any help would be appreciated thanks
Tags (3)
Kain_W
  • 3.72K
  • 102
  • 265
Re: Hub 3 - Solid red light
Hi sixtieskeith,
Thanks for your post and welcome to the community.
Apologies for the issues faced with the Hub, we'll need to get that replaced.
I've dropped you a PM so we can discuss further, the message will appear within the purple envelope icon.
Regards,
Kain
sixtieskeith
Hi Kain, i have sent you a pm. thanks for the reply its much appreciated.
Keith
