Dreamfish
  • 8
Message 1 of 10
Hub 3 Router Permanent Red Light
For the past 6 weeks my router has had a permanent red light. It definitely isn’t overheating. I have tried everything that I can find online (reset etc) but nothing. I have now noticed devices around the house are getting weaker at picking the signal up. Could do with rectifying quickly now working from home.
Kind regards
craig hughes
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: Hub 3 Router Permanent Red Light
Are you in Router Mode or Modem Mode ?
In Modem Mode the power light should be magenta.
In Router Mode the power light should be white.
In either Mode the red power light is an indication of over heating and most not be ignored.
Ensure that the Hub is in a well ventilated area and nothing is blocking the vent holes on the sides of the Hub.
If the Hub is in a clear area and is cool to touch and the red power light remains on the Hub must be replaced.
If the Hub is in a clear area and is hot to touch and the red power light remains on the Hub must be replaced.
Do not be fobbed off with "if it is cool it will be OK" or "Just blow a fan over it", this is dangerous advice.
When you go out or retire for the night ensure that the Hub is unplugged from the mains.
The only fix is a replacement Hub.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
Dreamfish
  • 8
Message 3 of 10
Hi thanks. I had already seen this post so have tried it and it is still red. I am in router mode.
Am I best to call for a replacement router or wait on here?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 10
I would say call in.
Dreamfish
  • 8
Message 5 of 10
Thank you. Do you know the best number to call?
Dreamfish
  • 8
Message 6 of 10
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 7 of 10
there is no "Best" number, just the standard number for customer services.
use that number.
My Broadband Ping - spgray
Steven_L
  • 4.12K
  • 304
  • 399
Message 8 of 10
Hey @Dreamfish,
Sorry to hear of the issues that you've been having with your broadband connection.
I have been able to locate your account and can see that you have an SNR issue on some of your downstream channels and a power issue on some of your upstream channel, we will need a technician to vist to fix this.
I have arranged for the appointment and you can find all the information that you need about your appointment on your online account and clicking My Account and Order tracking.
Steven_L
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 9 of 10
that wouldn't cause a red light to show on the hub though, unless the SNR issue is somehow causing the hub to overheat?
Dreamfish
  • 8
Message 10 of 10
Out of interest as a non techie, what does this mean? Is it not the router that is broken?
