Hub 3 Red light static
kamal22
Earlier mid-day the virgin hub 3 had a static red light, called tech support and told me it will go away!,
The router is almost 4 years old and now having issues with wireless connection which has interference with my device connections.
The person was more interested in taking a survey! than assisting me with the problem. I told him no.
Tried to do all the tech things he told me still same situation, can you please assist.
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Sabrina_B
Hi @kamal22 👋.
Thanks for reaching out to us.
We can assist you with this, we would need to bring you in for a private message to discuss this and resolve. Please look out for the envelope on the top right of your web browser or if you are using a mobile device it will be located under your profile icon.
Thanks.
Sabrina
2 REPLIES 2
Sabrina_B
Hi @kamal22 👋.
Thanks.
Sabrina
Hi Sabrina
Just wanted to let you know that the engnieer arrived and within 5 minutes chaged the router to a new one.
matter resolved, thank you once again.
kind regards
kamal
