Hub 3 Red Light
Dudleyn
My Hub 3 has had a steady red light for several weeks now and every few days, my internet connection becomes unstable. I found that if I reboot the hub that this resolves my stability issues, but I’ve read on here that this red light is usually a terminal issue and typically requires replacing. The hub itself, is in a well ventilated position and isn’t hot or overheating and most of the time works well, but as I work from home, I need to rely on it being stable, so any advice on what to do next would be appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
John_GS
Hi @Dudleyn
Apologies for the broadband issue.
John_GS
2 REPLIES 2
John_GS
Hi @Dudleyn
John_GS
Legend
It can be the LED is fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/   use the numeric HUB PASSWORD from the bottom side label.   ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry.   Is it normal ?
