Hi Louber2725,
Thank you for reaching out to us in our community and welcome, sorry to see your Router has a Red light even though you have tried all advised including switching it off when not home.
I will be more than happy to help further and will send you an invite into a private chat, once received please click on the purple envelope to start if still required.
First can you please try first checking all your internal connections are hand tight, this includes all equipment and any splitters, both powered and standard, once done please leave the Router on and push a pin/ paer clip into the reset hole at the back of the Router, keep pushed in for a full time 1 minute then allow 15 minutes to settle.
If once done the Red light is still on I will make sure you get all the help you need Via our private chat.
Paul.
